Thread: springs
    Regular Member i5aces's Avatar
    andover
    Default springs
    while i was fitting new discs and pads all round on saturday i noticed that the n/s/r spring has snapped so i think now is a goot time to replace them for lowered ones, i dont want to go to low as there are loads of speed bumps and crappy roads round here, so was thinking if i got <30mm springs that would lower my sri by 15mm is that correct,
    the thing is i cant seem to find any for the 3.0 cdti,
    also its not something i have ever done or seen done before so as much as its going to pain me to do so i will be getting the garage to fit them, is it worth doing the ARB,s and droplinks at the same time as the car is making some horrible noisies on uneven roads,
    sorry for the long thread
    and thanks for any info you guru's can offer
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    What are the axle weights on your car, inside drivers door on pillar.
    I imagine the ones on LMF should be ok.........
    http://www.lmfvauxhall.co.uk/store/p...at=2289&page=1
    andover
    the plate on the car reads
    2125 kg
    3725 kg
    1-1160 kg
    2-0980 kg
    not sure witch are the axle weights
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Quote Originally Posted by i5aces View Post
    2125 kg
    3725 kg
    1-1160 kg
    2-0980 kg
    Your front axle weight is 1160Kg and rear 980Kg. So i imagine you will need the bottom ones in the drop down list.
    Part No. 10-65-007-07-22
    1131-1230Kg
    I'm sure a quick call to LMF would confirm this.
    cheaper than Ebay too.
    andover
    cheers mate,
    would it be worth doing the ARB and droplinks at the same time as usually i would do it myself but like i say i have never done it before and wouldnt want to balls it up, surley it would be cheaper to have it all done together than have to go in twice, from what i have read its not that much for the parts, couple of quid for each ARB and about 40 for the drop links so its just how much extra the garage will charge.
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    if it was me i would.. drop links are about £30 max for a pair from ebay, not sure about stealer prices.. some people also change the trailing arms on the rears while their at it.. about £25 a set
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
    Will tighten up the ride and make it feel like new with all that running gear replaced,,
    andover
    thats what im hoping as its a bit sloppy and sounds horrible unless driving on flat roads, so if i say about £200 for parts just need to find out what the garage will rob me of now.
    andover
    well i have found a set of springs for £100 but the thing is there advertised as for 1.8/1.9/2.0/2.2/3.2 petrol for 2002-2008 the shop tells me these will go on my 3.0 cdti no probs can anyone confirm this as i thought diesel engines were heavier,
    Jun 2007
    Black Country
    Stick with the ones off LMF, they know what there talking about and the delivery wasn't too long either
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    They might go, but the 3.0CDTi is the heaviest engine and I'm not sure how they will cope with the extra weight.
  1. replacing standard springs with Sri springs
    By mon in forum Handling & Braking
    Last Post: 31st December 2012, 22:03
  2. springs? coilovers? shocks/springs?
    By Dan. in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2011, 19:01
  3. Replies: 5
    Last Post: 21st July 2010, 16:14
  4. vxr springs
    By supersione in forum Handling & Braking
    Last Post: 18th July 2010, 16:21
  5. 2.0T SRI Springs
    By Baz07 in forum Parts for sale
    Last Post: 9th July 2008, 13:28
