Results 1 to 10 of 14
Thread: Gas Engineers advice too, plz??
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    Default Gas Engineers advice too, plz??
    I have an Ideal Isar m30100 combi boiler. Supplies hot water ok. Problem being, when the central heating is on, it does not swith off when the heating reaches thermostat temp. If i then swith the hot water on, it diverts correctly and then it will set to rest, which means the central heating is off. Not a massive problem if were in during the day, but I noticed the problem initially when I woke up and thought....it's a bit warm in here.
    Any thoughts or advice on this appreciated.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Thermostat defective? I take it that the boiler is cutting in and out when just heating is switched on?
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Quote Originally Posted by Ste View Post
    Thermostat is hard wired and swiches(clicks) when temp is reached(flame symbol goes out too). So i think thermostat ok. Boiler does not respond to signal but does divert for hot water demand then switch off correctly.
    could it be diverter valve??
    Regular Member vauxhall-john's Avatar
    fife, scotland
    sounds like a possible pcb fault to me, worcester had a similar fault on the non condensing greenstar range was corrected when replacing pcb, could also be a sticky diverter valve hth
    Regular Member vxr-i-wish's Avatar
    Nov 2009
    Quarry Bank, W.mids
    id say thermostat, or diverter valve. these two things are regular things to pack up.
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Quote Originally Posted by vxr-i-wish View Post
    Not too expensive.....????
    Worcs/Staffs/Westmids (ish)
    Room thermostat, faulty relay?
    Room thermostats are £10-£50 (ebay).
    Try to find the maintenance manual for your boiler though....
    I've just fixed my central heating myself for £7.50, I got sick of so called engineers trying to tell me I needed £300 worth of repairs or a new boiler. Two thermostats and a bike pump was all I needed.....
    They're really simple to work on and as long as your not messing with the gas, your pretty safe.
    I actually find it offensive that some of these guys are allowed to call themselves "engineers".
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    confused
    Quote Originally Posted by Birchy63 View Post
    I tend to agree with you on most of that, there are some good registered Gas Engineers around here but you pay through the nose for them and have to wait weeks or months. There is a shortage of decent ones the the good ones are taking advantage of the situation imo.
    My thermostat appears to be working, clicks on and off as and when set and room temp is pretty normal. Just not switching off the boiler when temp reached.....
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    So to clarify. The demand light on the boiler goes out when the room temp is up to thermostat setting, but the boiler continues to burn?
    If this is the case, it sounds like a dodgy PCB to me. But it works OK with hot water alone? I guess you don't have a hot water storage tank?
    Quote Originally Posted by CHRISK View Post
    Then boiler isn't seeing the input change from the thermostat then perhaps maybe?
  1. Replies: 10
    Last Post: 26th May 2010, 15:20
  2. How Engineers Think
    By boba in forum Comedy & Humour
    Last Post: 3rd November 2008, 20:08
  3. Any telecoms engineers around - HELP!!!
    By Angel Boy in forum General Chat
    Last Post: 23rd August 2008, 21:28
  4. V6 engineers
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2008, 08:54
  5. Any engineers out there?
    By blr123 in forum Detailing and Car Care Discussion
    Last Post: 22nd February 2006, 21:34
