Thread: fog lights
    Regular Member Mickyboy's Avatar
    Cambridgeshire
    Default fog lights
    My car is still under its 3 month warranty from the local garage, i said to them about the fog lights having water in them,
    Is this a common problem with the fog lights as they are quite low in the bumper?
    Hopefully il get them to replace them as i can assume once water has got in there it will only happen again.
    Edinburgh
    yes it is quite common especially on the passenger side under the washer bottle. I believe there is a fix for it or a revised design or something. Have a search on here and I'm sure you'll be able to find it. being under warranty, hopefully Vx will sort it for you, if not you can probably drill a small breather hole in the fog somewhere.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    This is often due too water leaking into them from above espically the passenger side , due to it being under the washer bottle other causes to check are cracked lenses from stones.
    or badly fitted caps at base of unit all are known reason,s for water in th spotlight,s
    and still loving it
    Edinburgh
    you can dry it out by taking the cap off the bottom, switching on your fog lights for about 5-10 mins and then replace the caps and see if they will up again. Another tip is when filling wiper fluid, don't fill it as full as you can get, try to keep it below the seal between the bottle and the filler neck.
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    another tip is to put one of those silicon bags in it once youve dried it out ..........worked for me
    Cambridgeshire
    least i know im not alone with the fog light issue, il see what they do on the 13th when i take it in for some warranty work (exhaust bangs on floor pan when at low revs)
    Cambridgeshire
  1. Brighter Lights for side lights, Vectra SRI150
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2011, 23:50
  2. Replies: 2
    Last Post: 31st March 2010, 13:30
  3. Philips bluevision h7 head lights & side lights brand new
    By davidlewis24 in forum Parts for sale
    Last Post: 19th March 2009, 22:42
  4. Dark lights and Rear Lexus lights finally fitted
    By Leviathan in forum Styling
    Last Post: 29th February 2008, 22:35
