Results 1 to 10 of 17
Thread: i thought the egr?
    Glasgow
    Default i thought the egr?
    Ok well guys it appears my car bad luck comes in three's?
    i went to go to my mates house to replace the rear shocks and control arms, and when i left the house i felt the car was.. differant.
    then i relised, basically no power below 2k rpm.
    Yes immediatley i checked on here and went thru threads and posts and i thought the boost sensor and egr valve.
    so i got their and took the boost sensor out and gave it a clean, even though it wasnt coked up.
    i then took the egr off and that was coked quit a bit, so i went to take the egr apart and relised i didnt have any torx or allen keys to get the screws out so i cleaned what i i could from the egr and put it back together.
    But, you guessed it, no differance.
    im thinking either,
    A: i do need to take the egr apart and make sure its no coked up inside or whatever
    or
    B: its something diff.
    there is no engine light or engine codes, and no smoke comming out the back.
    i was thinking about buying carb cleaner and spray that thru n see if that helps?
    any ideas?
    its the 150 cdti.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Defo a full clean of the egr is 1st port of call.
    Also a quick visual check of the swirl bar wouldn't go a-miss.
    Regular Member Vecmaniac's Avatar
    Oct 2007
    Morpeth, Northumberland
    Just had the same prob... Defo check the 'how to' out on egr cleaning. had to do it to and it really can work!! Saved me a buck or two!
    WOLVERHAMPTON
    have a look for the How 2 on properly cleaning the EGR, i had the same problem the weekend, cleaned the egr and the boost but no difference, its the solenoid that causes the problem it gets really corroded i followed the instructions on how to remove it and clean it up car now runs great
    Cornwall
    I'm no expert by all means but I did this job on the weekend after having the same problems as you.
    Follow the how 2 and make sure you open the solenoid and clean that. It's the only thing that will make a difference. If you want to test the actuating pin on the solenoid before opening it up, connect a 12v battery to the pin connectors in the plug, the pin should osculate, if it doesn't it 100% needs cleaning.
    Here's my solenoid, you can see the problem.
    Good luck.
    Glasgow
    well last time i drilled a hole in the part within the how to, but i could no for the life of me get the solonoid out! i tried knocking it, banging it, hammering it everything so inside that part has never been cleaned.
    think i'll try tackeling it next weekend, maybe the fact it doesnt give boost before 2krpm will prevent me flooring it and maybe save me some fuel!
    thanks for the great info lads!
    if any one is any good with regards to suspension/knocks etc please look at my other thread!
    thanks again
    Cornwall
    Quote Originally Posted by twaiter View Post
    You've got to get a nail punch (or similar) into the hole, through the spring and on to the top of the cylindrical section. A good hammer blow with the face of the solenoid sitting on a vice will loose the innards.
    Glasgow
    guys, i drove to work tonight and the lag seems to be really bad, it wasnt to bad comming here but started to get really bad, then upon turning off the engine it juddered quit a bit!, so i started her up again and she juddered doing that aswell. done this a few times and each being the same, does the egr cause these issues?
    Cornwall
    The EGR regulates the Exhaust Gas entering the manifold at low rev ranges, between 1000 rpm to 2300 rpm, so yes, a sticky valve/solenoid can cause the lumpy idle and juddery start/stop.
    I had all the symptoms you describe through this thread, I did the work on Sat and my car is running sweet again.
    Glasgow
    thats fantastic, thanks very much for the help.
  1. DMF not as bad as I thought
    By rockafella8587 in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2012, 19:46
  2. Some Thought TV
    By VauxVeteran in forum The 'Off Topic' room
    Last Post: 26th June 2009, 03:06
  3. ...and you thought you were having a bad day!!
    By Vaux-Man-G in forum Comedy & Humour
    Last Post: 27th February 2009, 17:06
  4. Just Thought I'd Say Hello!
    By joejdx in forum Introduce yourself.
    Last Post: 3rd February 2009, 08:49
  5. Thought you might like?
    By morbid movie in forum Quick Photo Album
    Last Post: 21st December 2008, 13:56
