Thread: help my at a loss
    newcastle
    Default help my at a loss
    ok heres my problem i got spanner light on its turned off now and the orange engine light is on took into garage they said fault code was p0111
    Intake Air Temperature Circuit Range/Performance Problem i have cleaned maf and egr valve out but light is still on and car has no power under 3000 revs in any gear im gathering it is not them so what now im stuck and skint so any help
    Bristol
    Vehicle : CDTI 150
    Evening fella, what engine is it?
    newcastle
    its 1.9 cdti 150
    Bristol
    Vehicle : CDTI 150
    Normally EGR, did you strip the solenoid as per the How 2?
    Also check the swirl vale rod is connected and operating, just do a search on here for info.
    Would also check the vacuum pipes, the vac pump is on the passenger side of the engine towards the front, its a roundish silver thing with a couple of thin pipes, check these for splits.
  1. oil loss?
    By cjam27 in forum Engine & Drivetrain
    Last Post: 25th May 2011, 00:34
  2. loss of power
    By rick1965 in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2010, 15:54
  3. V6 Coolant loss, Help!
    By v6boy in forum Vectra C / Signum Troubleshooting
    Last Post: 12th September 2010, 16:01
  4. loss of power
    By jonnynufc in forum Engine & Drivetrain
    Last Post: 15th May 2009, 00:50
  5. Power Loss 2.0T
    By gibbon7000 in forum Engine & Drivetrain
    Last Post: 30th April 2009, 23:13
