Thread: Replacing Track Rod Ends...
    Regular Member Jezzy's Avatar
    S.E
    Default Replacing Track Rod Ends...
    Got the day off tomorrow, and the weather looks good (at last!), so I'll be changing the track rod ends. Looks fairly straight forward on Haynes, and I've bought a ball joint seperator from Halfords. Does anyone have any tips from prior experience? Ta.
    Sunny Dartmoor
    I've done mine and they're very straight forward,just remember to count the turns it takes to get the old one off and when fitting the new one put it on the same number of turns,also get the tracking checked,good luck m8.............
    S.E
    Quote Originally Posted by glenboy View Post
    Cheers Mate. What I'm going to do is measure the distance between the centre of the existing ball joint and a fixed point on the track rod, in case the new and old rod ends are slightly different lengths. Then screw on the new one until it's the same distance as I measured the old one to be.
    East Midlands
    Theres another way of doing it,wrap some tape around existing TRE and screw the new one up to it,then get the front tracking done ..easy.
    Regular Member myelite150's Avatar
    Nov 2009
    south wales,Cwmbran
    i used chalk to mark the back end of track rod then just screw new one to the mark thats all really shud be straight forward muck good luck anymay
  1. Replies: 5
    Last Post: 15th July 2010, 21:33
  2. track rod ends
    By monty2000 in forum Suspension, Wheels & Brakes
    Last Post: 3rd May 2010, 10:23
  3. Track Rod Ends or Inner Track Rods
    By Padster72 in forum Suspension, Wheels & Brakes
    Last Post: 28th April 2010, 11:41
  4. Track rod ends
    By Kermit in forum Suspension, Wheels & Brakes
    Last Post: 30th June 2008, 18:00
  5. Track Rod Ends
    By parapaul in forum The 'Off Topic' room
    Last Post: 13th March 2008, 01:05
