Results 1 to 10 of 17
Thread: Spanner light won't go out
    Aylesbury
    Default Spanner light won't go out
    Hi guys
    I have found this forum a great source of useful info. Hopefully, someone can help with this.
    Signum 2.0DTi 50K
    Two weeks ago, i came out of work, jumped in the car and started it, then it went into limp mode and spanner light came on before i could drive off.
    Turned off engine and restarted it no problem, no limp mode.
    Now every morning the spanner light comes on for a minute or so and goes out.
    I understand this to be because an incident has occured and the light is on to tell you.
    It has not gone into limp mode since, just the light coming on when starting from cold.
    I borrowed a reader and got codes P1105 and P0105. I erased these codes thinking that will turn the light off, but it hasn't.
    The light comes on every morning still.
    When i scan with the reader again, no codes present.
    Any ideas?
    Do i have a problem? or is it a random incident?
    I have read the "how to" clean the boost sensor and happy to get that done if its required.
    Just want the damn spanner light to go away....gives me the shivers every time i see it.
    thanks in advance.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    if it comes on the goes of after 2is mins could be the glow plugs
    Aylesbury
    Quote Originally Posted by mattv6diesel View Post
    Would a code be stored for the reader to see if it was glow plugs?
    (had glowplug changed last year at 35K)
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    P1105 Dual Alternator Upper Fault (what ever that is !)
    P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
    As I am not sure that an alternator fault would cause limp mode, then I would start with cleaning the MAP sensor and check wiring. If you disconnect the battery while you do this, the light may not come back on again.
    Aylesbury
    Quote Originally Posted by Ste View Post
    i had them both to do with MAP sensor.
    What are the consequences of disconnecting battery?
    (stupid question, but you never know)
    Stockton on Tees
    I had this on my 2.0 DTi Vec and its was the Heater Plugs. No code stored either!!
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Disconnecting battery can clear fault light (as long as you have cleared the problem of course)
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    make sure you have the radio code before you disconect the battery just in case!, or you will have to pay to retrieve it from vx.
    Aylesbury
    Quote Originally Posted by the-wizard View Post
    i have all the docs with the car, where would the radio code be?
    Its a SATNAV CD70 i think.
    Full Member
    Bristol
    You should have a red car pass with the vehicle.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
engine spanner light wont go out
