Thread: Koni Springs On Ebay
    Dec 2005
    RUNCORN
    Default Koni Springs On Ebay
    are these any good and what do all you peolpe think. i want to lower the car a bit but not sure on how to go about it in the best way i.e best spings or suspension kit looked at irmscher kit and wow !!!!! what a price thats well over the top so apart from some of you saying just sit in it that will lower it i am open for some help from you all out there
    [Ex]Admin Duncan's Avatar
    You got a link to the specific springs on ebay you're talking about?
    Koni springs are good -and you'll get a far better ride if you pair them up with some matched dampers.
    The main thing you have to make sure is that you get the right springs for your particular engine (front axle weight).
    Dec 2005
    RUNCORN
    so they will be no good on there own with the vx dampers then
    They'll be okay(ish) with the Vx dampers, but if you put lowering springs onto the standard dampers you'll wear out the original dampers more quickly. You'll also get a double bounce as the dampers aren't uprated to match the stiffer springs.
    As you've got an SRi you'll have uprated dampers on it already - not up to the same spec as the Irmcher ones though. Your SRi will also already be 20mm lowered compared to the other models - so depending on the springs you're looking at, you may only lower it another 10mm.
    If looks are your main priority then some lower springs along with your SRi dampers will do that and give you a decent ride/handling.
    If handling is your top priority, and looks secondary, then a set of dampers matched to the lowering springs will give the best handling.
    HTH
    Dec 2005
    RUNCORN
    yes i only want it to drop a bit on the front as i think it sits up to high it dont handle to bad but have been told it will handle a bit better with just springs i would love the irm kit but for 800 quid off irm its a bit over the top for everyday use i think
    ive got koni springs on my standard shocks and i dont get any double bounce.
    mines dropped by about 30mm
    Dec 2005
    RUNCORN
    oh that sounds good how does it ride but was wondering about my 19" wheels will there be a problem
    Regular Member The Doc's Avatar
    'Norf Yorks.
    I got 888 springs on my SRi shocks and handling vastly improved. If anything it felt like the standard suspension as fighting itself.
    Dec 2005
    RUNCORN
    did it drop you car down much vectra 20t you say 30 mm i wonder what it would be on mine and would the bigger wheels make a diffrence
    has droped it down quite a bit
    iam on 18's and have no problems
    tell a lie i now struggle to get on the drive with my irmscher front spoiler
  1. Koni FSD + H&R springs
    By BYGino in forum Handling & Braking
    Last Post: 11th September 2012, 20:17
  2. Koni springs???
    By zazaszazas in forum Handling & Braking
    Last Post: 29th March 2009, 00:54
  3. Koni Suspension Springs Kit
    By coopster in forum Handling & Braking
    Last Post: 11th April 2008, 10:32
  4. Koni FSD shocks & springs
    By Matt21385 in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2008, 17:45
  5. Koni FSD & H&R Springs
    By mark1319 in forum Handling & Braking
    Last Post: 27th November 2007, 19:39
