Thread: weird indicator problem
    edinburgh
    Default weird indicator problem
    Hi all. My 2004 2.2dti sxi has developed a weird problem.My front nearside indicator light is constantly on when i switch the headlights and sidelights on. it goes off for a few seconds when i indicate but goes on again after a few seconds when the indicator goes off again. Does anyone have any ideas of what this could be?
    many thanks all
    Full Member Big Sig's Avatar
    yes, its in the manual, your car thinks you have a sidelight bulb out, double check them/and/or clean the contacts for them.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    technology
    edinburgh
    thanks mate many thanks for your quick response!
    edinburgh
    ****** technology i agree!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It uses the indicator as a back up corner marker if the side light build goes. Searching on here will find the answer too. At least it is the near side, which is easy to do. Just remove the washer bottle filler neck (release the securing tab onto the slam panel, then twist and pull up and off the bottle - refit is the reverse), open the battery box cover and you have all the room you need.
    edinburgh
    rolleyes
    Thanks guys for all your help. finally trtaced toe offending bulb and changed it! cheers. couldnt have done it without you.
    edinburgh
    rolleyes
    Top tip, have a browse through the manual
  1. very weird issue with indicator
    By gregj in forum Electrical & ICE (including SatNav)
    Last Post: 2nd April 2013, 19:05
  2. Weird Problem with PC..
    By macdad in forum General Chat
    Last Post: 28th March 2012, 23:36
  3. Weird problem
    By wayne10244 in forum Electrical & ICE (including SatNav)
    Last Post: 27th September 2011, 19:12
  4. Weird indicator/light problem
    By mickynoakes in forum Electrical & ICE (including SatNav)
    Last Post: 25th October 2010, 23:23
  5. weird possible ABS problem?
    By Xerath in forum Suspension, Wheels & Brakes
    Last Post: 11th February 2010, 15:46
