Thread: keys
    Dartford
    Default keys
    does anyone know what type of keys will programme to facelift vectra.
    i currently have two button flip, i want a spare made - just wondered if the older remote type that doesnt flip out will programme.
    if anyone can tell me what type they have and the part number ifthey know it.
    thanks
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Mine is a standard three button fixed tip (non-flip) key
    Lock, Two stage door Unlock and boot-unlock.
    Dartford
    can 3 button be used on car that originally had two button remote?
    can anyone get hold of cheap new keys? what sort of price are they from stealers?
    robsey... cheers software all working again.
    Dartford
    Anyone?
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    I don't know for sure Rick,
    I would like to say yes, as long as it has been programmed to your car's CIM unit.
    Also assuming that it has been divorced from the previous car's CIM module..
    If not divorced, then it will be no use to anyone....
    Dartford
    Only want new key. But seen two button flip like my existing and two button none flip looks same but doesn't fold.
    Just wondered what other keys people have with vec c.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    There are various options for key dependent upon whether your car has: -
    heat dissipation windscreen,
    Estate F35, or other models,
    315Mhz or 433Mhz transmitter,
    powered tailgate open / close or not ,
    long or short range
    Dartford
    Robsey... Why do you always make things complicated
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    I started to make up another spread sheet of various types and specifications...
    It took nearly an hour for just the flip-type, before I got fed up and said "oh bog it!!".
    In all honesty, I don't suppose it matters that much, as long as you tech 2 or Op-com pair it to your car's imobilizer and CIM modules.
    And of course, as long it was un-paired from the donor vehicle.
    Flip or not...2 button or three button....as long as it is from a Vec C or Signum, then it should work.
    As an example, I run a full can radio (CD70) from half can CIM and BCM!!
    Just ensure that the key you go for is at the correct frequency...read the back of yours...it should say either 433MHz or 315MHz. The one you need has to have the same frequency marked on it.
  1. Help with keys
    By Rickiw in forum Electrical & ICE (including SatNav)
    Last Post: 14th January 2010, 21:47
  2. new keys????
    By mick 1986 in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2009, 23:35
  3. Keys
    By craig-k in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2009, 19:40
  4. different keys
    By Gr4eme in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2007, 20:16
  5. keys
    By fellie in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2007, 13:01
