Thread: turbo not spooling
    devon
    Default turbo not spooling
    hi im new new here and with a problem ( suprise ) i got a 2004 19 cdti owned from new with 110k on the clock , had a leak in the inter cooler which i replaced yesterday , the old one had swollen up / the veins top and bottom had expanded , hence it split .
    i noticed water in the cooler so i assumed it had entered some how , possibly froze in the cold weather we had , hence the expansion .so new one fitted ,off we go on test ,i only get 500 yards up the road the revs hit 3000 rpm theres a loud pop and it dies .
    the turbo wont spool up now and the intake hose from the cooler to the manifold is collapsing when reved . any one had these issues that can help . thanks in advance
    Has a hose popped off?
    devon
    thats what it sounded like, had a quick look yesterday ( nothing obvious ) will investigate more tomorrow , had to abandon car
    hope thats all it is , thanks
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    yes is you get some one to raise the revs you should here the boost leak
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    If there are no hoses popped off that you can see it is either a hose that has popped off/split at the turbo or the intercooler has burst.
    Hope its just a hose m8.
    Gazza4
    devon
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    me too, as said just fitted new intercooler , cant here any air leaks like i could with the old cooler, it seems strangled the hose to the manifold collapses when reved and its not sucking much through the main intake to the air box
    thanks
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    might be worth checking the turbo spins and not seized
    devon
    Quote Originally Posted by mattv6diesel View Post
    thanks sounds expensive
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    we hopefully not but now when it boosts its building up pressure not lossing it through holes might of been to much
    devon
    yea gotcha , its almost like a blockage in the intake system so im guessing turbo , would need to remove & check it out , will try and look tomorrow , thanks
  1. Replies: 19
    Last Post: 6th September 2014, 13:54
  2. Turbo Technics Hybrid turbo details.
    By nutron in forum Diesel Engine related
    Last Post: 28th February 2011, 22:57
  3. TD04L14T turbo for Z20NET (2.0 turbo)
    By Caveman_nige in forum Parts for sale
    Last Post: 10th October 2010, 13:23
  4. re turbo not spooling
    By delbert in forum Vectra C / Signum Troubleshooting
    Last Post: 6th March 2010, 23:00
  5. is it possible to change 2.0 dti turbo to 2.2dti turbo
    By EURO G in forum Engine & Drivetrain
    Last Post: 22nd October 2008, 07:35
cdti turbo not spooling up
