Thread: 2 probs on my veccy
    northants
    confused 2 probs on my veccy
    my heater blower has been playing up ie not blowing on any of 1-7 settings or def or air con but hot air has been coming out from vents just takes ages . now sometimes thefan works for a few seconds when first started sometimes doesnt then will kick in after sometime of driving then cut out again. i get lights to switches on buttons. also sometimes makes a noise as if fan is catching on something but took out pollen filter couldnt seen anything there.
    now today my passenger wiper has stopped working , drivers side works fine as does rear wiper . the passenger wiper moves freely if tried manually but makes a slight clonk noise .
    heater problem started 7 days ago now wiper could they be connected in anyway ?
    heater is a dual zone climate control
    Regular Member r.bailey63's Avatar
    Mar 2007
    Stockton on Tees
    Sounds like heater motor and wiper linkages
    Regular Member david.aka.judas's Avatar
    Suffolk
    if you can hear a repetative clickinh noise behind the dash, that the re-circ servo unit.
    northants
    would the re-circ still work on the van intermittently
    northants
    Eek update
    thanks guys
    i have checked wiper linkages and lower one connected to pssenger side was broken/disconnected. i reconnected and used a couple of cable ties to effet a temp repair so at least that is working for the moment .
    i took out the pollen filter again . and as i was in daylight this time noticed a pool of water under it, the drain hole was blocked ,so unblocked this ,so no water siting there ,but still heater fan doesn't blow , (only intermittently) if motor had got wet , is it likely to work again once dried out ?
  1. Drosser Veccy B old hand Veccy C virgin
    By drosser in forum Introduce yourself.
    Last Post: 27th November 2012, 06:42
  2. 150 probs
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2011, 22:54
  3. Thermostat from a 1999-02 veccy onto a 2003-05 veccy?
    By Drazek in forum Engine & Drivetrain
    Last Post: 9th January 2011, 22:21
  4. Few probs :)
    By Danialj32 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2010, 20:42
  5. big probs
    By dextrovix in forum Engine & Drivetrain
    Last Post: 30th November 2006, 08:10
