Thread: tv aerial
    Regular Member VEC-MAN's Avatar
    Nov 2007
    LEICESTERSHIRE
    Default tv aerial
    right can someone recommend me a tv aerial please, it`s for outside, suitable for free view, digital. i`ve been quoted £180 + £30 per extra point got 4 in total £270. i`m more than capable of installing my own just could do with some advice thanks guys.
    Nov 2007
    LEICESTERSHIRE
    What no one fitted an aerial.
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    It depends on your signal strength/quality but a 'normal' aerial off the shelf from B&Q etc should be fine. I have fitted several in the loft and they work fine. Sometimes you need to have them mounted outside and you can get 'high gain' ones if required.
    As for multiple points, you can simply connect multiple leads to a single aerial if the signal is good enough. Otherwise I have fitted an aerial in the loft for each interior lead/point. It's cheaper and easier buying extra aerials than any complicated power booster signal splitter.
    East Midlands
    This site might help you VM.
    http://www.digitaluk.co.uk/home
    Regular Member kns's Avatar
    Northampton
    Quote Originally Posted by macdad View Post
    link not working here Mate
    East Midlands
    Quote Originally Posted by kns View Post
    Seems to be a problem with there server,sometimes working ,sometimes not keep trying.
    Sep 2009
    Swindon
    If you are a going for a new aerial and 4 points, I would get a distribution amp fitted in the loft also as splitting the cable with a 4 way will reduce the signal quite badly.
    As for an aerial and amp, ebay is your best bet for all of it.
    Frenchman
    Regular Member BIG-G's Avatar
    Oct 2009
    thurso
    havent you thought of sky and just getting freeview with them its just 30 pound for the card and you just pay for the install.as some digital aerials cost about the same
  1. vec c aerial
    By fiend61 in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2012, 21:33
  2. aerial
    By matreya in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2012, 15:42
  3. How much is a new aerial?
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2010, 15:00
  4. OEM sat nav aerial
    By Saxman in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2010, 13:34
