Results 1 to 10 of 22
Thread: Help Brake rewind tool
    Regular Member eaglepva's Avatar
    Up North
    Default Help Brake rewind tool
    Anybody got a rewind tool i can borrow, im in hartlepool, but willing to travel or pay for recorded post their and back also pay a deposit if required.
    Ash
    Regular Member myelite150's Avatar
    Nov 2009
    south wales,Cwmbran
    hi mucker now i got the box tool that i used on one side of the brakes but as i made myself a proper tool i used it for the other side i am willing to post the tool to you know probs and it does work you just need to push it hard and turn it with a 3/8th ratchet tool
    Up North
    Hi mate, that would be grate mate car currently sat outside on drive as i can get hold of a rewind tool and the long nose pliers dont seem to work. How do you want paying for the postage mate, can also pay a deposit if required untill tool is returned to you.
    Cheers and thanks.
    Ash
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    Quote Originally Posted by eaglepva View Post
    Ash
    I did mine today and just used a G clamp
    Nov 2009
    south wales,Cwmbran
    dont worry about the deposit mucker i am a trusting guy so if you send me your addy by private message and i will nip to posty to have it weighed and see how much it is, also me and damiens are trying to set up a tool hire by post on the site and has been passed by admin so you could maybe keep it until someone else wants it (aslong as u can keep it to han d)
    this will be for the box tool mucker ok just to let u know and u need a 3/8th ratchet spanner ok, i also got a few tips on best way to use it too i didnt need a g clamp either u just need a bit of elbow grease and push it hard at first whilst turning then it just winds in itself with slight pushing (clockwise)and i will give u my mobile number if you get stuck so i cant say any fairer than that mucker ok
    Last edited by myelite150; 28th February 2010 at 20:11. Reason: just added more info
    Up North
    I did with the fronts mate, but the rears need to be wound back in.
    Jun 2009
    bradford
    yea i know mate.did my fronts and rears today, as you tighten the clamp on to the piston keep turning and it winds in" SIMPLES"
    Up North
    upto you mate, if you want me to keep it untill somebody else needs it thats fine i got a safe garage. Or i can send it back once used. I have ratched spanners etc. Any pictures of the tool so i can get a idea of how to use it.
    Nov 2009
    south wales,Cwmbran
    this is how i used the caliper for support by refitting bottom caliper bolt to top carrrier hole
    and just unclipped the hanbrake cable on suspension arm
    i not got a pic mucker and when you get it you can only use it one way and it will only fit on one way too
    a little fiddly but it good tool i ground down the small edges (u will see) and put them in hole so that the other two pins are on the outside of the piston u will get about 3/4 of a turn out of it then you re fit it simple muck .
    search on ebay for it and see one
    Up North
    Hi mate did you get a price for the postage of the tool.
    Ash.
    P.s have looked on ebay but cant find the one you refer to.
  1. Brake Rewind Tool
    By LeeU in forum Suspension, Wheels & Brakes
    Last Post: 10th September 2011, 11:21
  2. Brake rewind tool
    By scotty84 in forum West Midlands (RO - vacant)
    Last Post: 26th March 2011, 22:01
  3. Brake rewind tool.
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2010, 08:32
  4. brake rewind tool
    By Darren68 in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2009, 16:24
