Thread: heater probs, help guys
    PRESTON
    Default heater probs, help guys
    After weeks of my heater bugging me and reading threads,i got round to it today and i dont get it. Veccy is a 1.9 CDTI 55 plate Design. Stripped out glovebox and i can see the red heat levers, so,turn it to full cold and they move, then to full hot and they move partially. If i turn to cold again, then hot and push the levers,they go all the way to hot.Turn back to cold and they move fully to cold..Try full hot again and its same partial movement.I have soaked them in wd40, to no avail. Now heres a weird thing, if i have pushed them to hot, with the dial reading 26, switch off the ignition and wait a few mins, the lever goes back to full cold, without me touching anything!!!!!, Totally baffled,,,,,,what do you guys think??? servo or control panel,
    Cheers in advance
    PRESTON
    Sorry, posted this in the wrong section, iknow,,damn noobs, could site admin please correct my error, thanks
    PRESTON
    No ideas?? ok, np, maybe its outside the knowledge of this forum. Gonna take her to the stealers tomorrow and will post results, in case anyone else gets this problem.
    Regular Member v6boy's Avatar
    PRESTON
    Trim : GSI
    Hi,
    Did you ever get to the bottom of this problem, i'm having trouble that when oh hot its never very hot.
    Full Member Big Sig's Avatar
    I'd replace the servo as if they seize and free them selves up they can strip the teeth off.
    PRESTON
    Trim : GSI
    I've had the glove box out earlier, eill this be the thing with the red arm? Cause when i turn from cold to hot it seems to travel for a good distance. (Clicking all the way of course!)
    PRESTON
    In the end it was a new thermostat that cured the problem, once that was changed all was toasty. My car has semi automatic climate control and i was told by the teccy's at VX that it relies on heat being in the water pipes before the heat control servo will operate to its full movement. Dunno how true that is,but it's all good now.
    PRESTON
    Trim : GSI
    Was that at Perrys? I don't think replacing the thermostat on a V6 is easy/cheap so would be gutted if that didn't work. Engine still appears to run at normal temperature A bit of warm heat does come through, just not hot.
    When i take the return pipe off the heater matrix at the bulkhead, coolant does run out when the engines idling, not with any venom mind you, just a trickle
    PRESTON
    no it was Moorlands in Blackpool.
    that clicking might be the gears slipping due to the flap being 'stuck', maybe this thread will help.
    http://www.vectra-c.com/forum/showth...light=glovebox
    another thought is maybe you have an airlock in the heater hoses, i,m not to familiar with the layout of the V6, i have the 120 oil burner, LMAO
  1. big probs :(
    By andy76 in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2012, 18:48
  2. Help with a few probs please :)
    By Hobo in forum Vectra C / Signum Troubleshooting
    Last Post: 8th March 2009, 21:08
  3. Temp Gauge An Heater Probs Any Ideas
    By alshel in forum Electrical & ICE (including SatNav)
    Last Post: 3rd November 2008, 23:30
  4. A few probs..
    By Graeme in forum Suspension, Wheels & Brakes
    Last Post: 27th September 2008, 15:28
