Results 1 to 2 of 2
Thread: Bump Stops - Help
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Default Bump Stops - Help
    just fitting Eibachs & B6 but the old shock bump stops are too small & don't fit - do I discard, make them fit or buy some that do - what have other people done?
    Mar 2007
    Southport
    In the end I modified the bump stop to make it fit - I shortened it slightly & reamed it out with a sharp knife so that it fitted the fatter piston on the Bilstein B6.
    Intersting to note that the wiring bracket on the front strut is wrong so the electrical connectors are attached with tie wraps till I make brackets to fit - I may cut the relevant bit of the old strut & bolt it to the bilstein.
  1. Z30DT stops
    By Johnny-B in forum Y & Z30DT Specific
    Last Post: 9th August 2012, 15:14
  2. car just stops???
    By kiwiboy in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2011, 09:18
  3. 1.8 low power, stops when hot
    By gassy in forum Engine & Drivetrain
    Last Post: 27th May 2007, 19:06
  4. bump stops.....
    By jamesy in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2007, 00:19
