Results 1 to 3 of 3
Thread: strange noise from rear drivers side
    Liverpool....the red side
    Default strange noise from rear drivers side
    hi guys i have a 1.8 vvt 06 plate vec. this rather strange noise has appeared from around the drivers side rear wheel. it sounds like theres a piece of metal hanging of the underside grinding along the floor. naturally ive checked to make sure theres nothing hanging off which there isnt. it seems particularly bad when im in 1st gear and reverse.
    sorry for my rather vague description but does this sound familiar to anyone at all?
    many thanks
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Similar here..
    I get a tapping when braking (could just need greasing), and a metal knocking sound when turning left from the same wheel... slow speeds so same gears...
    Ok once moving, exhaust is fine also...?!?!
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Chris
    firstly check the brake shield isn't catching the disc,then check rear bearing,spin wheel and check for noise,rock wheel top to bottom,side to side and check for any play in bearing this is the most likely.
  1. help strange noise after cleaning out side throttle body
    By 6009tristanb in forum Engine & Drivetrain
    Last Post: 23rd February 2012, 17:52
  2. Noise from drivers side when turning
    By winnie2457 in forum Suspension, Wheels & Brakes
    Last Post: 3rd January 2011, 10:11
  3. PI + B4 fitted - clunking noise from drivers side front
    By mishima in forum Suspension, Wheels & Brakes
    Last Post: 12th July 2010, 20:20
  4. Strange noise - rear near side
    By dave200 in forum Suspension, Wheels & Brakes
    Last Post: 2nd July 2008, 14:12
  5. Wind noise from drivers side doors/ windows.
    By rosssri in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2008, 20:40
vectra c strange noise from rear drivers wheel
Vauxhall vectra c throttle drivers side front shock noise
04 dti vectra noise in back
