Thread: advice asap on egr valve
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default advice asap on egr valve
    need help with egr valve just took engine cover off but i cant get the plug off am i tryig to take the right plug off????
    or is it the clips that go all round if you know what i mean you can see them in pic by the pipe
    thanks
    Oct 2009
    Sandwell
    bump
    Regular Member R13hard's Avatar
    Devon
    Engine : 2.0 Turbo
    it's the whole clip that you have circled which needs to come off...
    On the underside of that plug is a little release catch, to remove the plug squeeze the plug at the bottom and top with your thumb and finger then pull it backwards. I hope that makes sense.
    its the same type of plug that is attatched to the MAF sensor
    Oct 2009
    Sandwell
    Quote Originally Posted by R13hard View Post
    i folloed the how 2 but broke one side of the clips so i didnt bother trying the other , i found my way really easy,, get some grips/pliers and press the release catch, really easy that way, the egr is in kitchen now having a nice soke in carb cleaner, so how do you clean the inside i cant even get a rag in there
    the amount of black **** on it was shocking, 5 years and 44k worth ill show pics of after and before
  1. Need advice ASAP
    By roverjay in forum Vectra C / Signum Troubleshooting
    Last Post: 21st August 2012, 11:23
  2. Ladies advice needed ASAP
    By Mrs K in forum Electrical & ICE (including SatNav)
    Last Post: 8th July 2011, 11:33
  3. Bit of advice regards to mpg screen asap
    By Devvo SRI CDTI in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2011, 22:55
  4. Need help/advice asap! Grille badge!
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2011, 22:44
  5. need advice asap
    By glynn in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2008, 21:38
