Thread: Key fob issue
    LONDON
    Default Key fob issue
    Hi , I need the help from you guys:
    Basically, I bought a 2nd hand transponder (key-flip type) to replace my damaged one. With that I managed to get my hand on a blade which cut and seems fine, now to the techie bit. Iím looking to programme the key and have few questions :
    Have an appointment with the dealer but was told that it going to be chargeable even if its didnít work. So the question I have is there a risk to not being able to reprogramme a 2nd hand key, which was used for a different car, albeit the same model car.
    Is there an alternative to going to the dealer in the London/North West area?
    The car is vectra c 2006
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    If the key has been cleared (un-paired) from the previous vehicle then it should be fine. This assumes that it was sold in working condition.
    If it hasn't been cleared, then it cannot be reprogrammed.
    Well not easily, and most dealers won't waste much time trying.
    Alternatively, see if any forum members in your area have Tech 2, Op-Com or Vaux Com...as they will be able to check the "status"of the key and in some cases program it for your car...assuming you have the car pass with the immobilizer code on it.and all other details, such as vin number etc....on full can vehicles (54 plate onward) this is also the audio pass number (4 digits).
    LONDON
    comperhensive answer, thanks a million
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Sorry about my resonse..it implied that on 54 plate vehicles, that the Audio pass number is the same as the VIN No. - This is not the case.
    On 54 plate onward (Full Canbus with quadlock connectors) the Audio pass 4 digit number is the same as the Immobilizer Code.
    On vehicles 52 plate to very early 54 plate (before october 2004) with half can-bus radios fitted with ISO connectors, the Immobilzer code is different from the Audio pass (radio and screen) code.
    Hope that clarifies it for you....
  1. Air con issue
    By harts1.9design in forum Electrical & ICE (including SatNav)
    Last Post: 12th June 2012, 11:26
  2. hid issue
    By Morephun in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2011, 10:30
  3. Hid a serious issue ?
    By Elahi_786 in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2010, 02:28
  4. DAB issue
    By qsdjdan in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2010, 01:12
  5. key fob issue
    By doghead632 in forum Bodywork & Interior
    Last Post: 25th August 2009, 10:22
