Results 1 to 10 of 23
Thread: Power Loss on 3.0 V6 CDTI
    Regular Member V6Andy's Avatar
    Plymouth sometimes Oxford other times
    Default Power Loss on 3.0 V6 CDTI
    Hi, I have the above in the SRI Esate varient, its done approx 40k now and have suddenly been experiancing a loss of power at random times.
    its always between 2,000 rpm and 3,000 rpm.... this is the scenario:
    low revs (any gear) floor it, accelerates fine, hit about 1500 revs and turbo spools up, get a quick bit of boost and engine dies (its lke someones yanking on the handbreak), makes a wierd noise like its trying to boost. eventually when it reaches 3,000 revs its like a rocket again turbo spooling up no problem, until I change gear or drop below 3,000 revs
    It will do this for a couple of days in a row then just kinda fix it self
    Its done it a couple of times now, and normally when im overtaking or really need the power
    Anyone else experiance this or have a soloution?
    The car is standard except for a courtenay filter and had its had its major service not long ago, no fault codes or smoke either.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I've been experiencing similar acceleration issues with my prefacelift 3.0CDTI, but I've not yet come to the bottom of the problem. Recently bought a new MAF sensor and will get that fitted soon. I'll report back if that sorts the problem.
    Another Y30DT with failed SCV by the sounds of it
    Time to get your blankety blank cheque book out sadly
    Short term solution and symptom check is to fill one complete tank with "diesel fuel pump cleaner" (not fuel treatment)
    Eventually the problem will get worse as the SCV deteriorates and eventualy the EMS will realise something is going wrong and will kill the engine power completely (meaning you won't get more than 30mph)
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    So you think I have SCV failure again?
    I think it's air related this time
    Quote Originally Posted by Celes View Post
    No, refering to OP symptoms
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I know
    Hijacking this thread I'm sorry...
    Mine's low on power and I can feel the turbo going on-off-on-off-on. I have turned the air filter around (I don't have the airbox mod) and it made it a bit better.
    Regular Member r.bailey63's Avatar
    Mar 2007
    Stockton on Tees
    I had problems with my turbo going on n off, boost pressure was all over the place and had lots of black smoke from the exahaust, turned out to be a tiny split in the intercooler.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by r.bailey63 View Post
    No smoke here
    There are two things that give this symptom away
    The sudden power loss at 2000rpm (just where the turbo should activate) and regaining power at 3000rpm
    Accompanied by hearing the turbo switching on and off continuously
    This is caused by the EMS not understanding the readings from the fuel pump (due to a blocked SVC) together with the revs
    It interprets this as low fuel requirement and so shuts the turbo off
    As the problem gets worse the band on lack of increases, could be as wide as 1500 to 4500rpm
    Eventually there is so little fuel getting through that the EMS just gets totally confused and puts the engine into safe mode, however you won't get more than 1500rpm as by then the SCV is completely blocked
    oh dear sounds serious, sorry but whats the scv? And going rate?
  1. 150 CDTi power loss
    By rockafella8587 in forum Engine & Drivetrain
    Last Post: 15th December 2011, 12:48
  2. Loss Of Power On 3.0 cdti sri - please help
    By L.Hamilton in forum Engine & Drivetrain
    Last Post: 14th June 2011, 18:00
  3. 1.9 CDTI 150 loss of power
    By Nick_206_180 in forum Engine & Drivetrain
    Last Post: 22nd January 2009, 20:57
  4. loss of power 150 cdti
    By SRI-150 in forum Engine & Drivetrain
    Last Post: 17th May 2008, 14:24
  5. loss of power 1.9 CDTi
    By ALD in forum Engine & Drivetrain
    Last Post: 5th January 2007, 16:25
loss of power signum v6 cdti
3.0 v6 vauxhall signum turbo problem
https:www.vectra-c.comforumshowthread.php103750-Power-Loss-on-3-0-V6-CDTI
vectra 3.0 cdti turbo
vectra c 3.0 v6 cdti power loss
opel signum 3.0 v6 cdti 2008 power loss
Maf sensor 3.0 vauxhall diesel
Signum 3.0v6 cdti 2000revs running rough missing
3.0 v6 cdti running rough on 1500 revs
Increase turbo boost on 3.0 v6 cdti
vectra 3.0 cdti holding bk
2009 3.0 v6 vectra turbo failure
vectra 3.0 cdti power loss
vectra cdti loss of power
signum v6 slight power loss
y30dt boost killed at 3000 rpm
vectra c 3.0 v6 cdti holding back on full throttle
v6 vectra cdti power loss emissons light
vectra v6 turbo diesel lost power
vauxhall signum 3.0cdti loss of engine power
3.0 cdti no power after 200p rpm
3.0 v6 cdti vectra not revving over 3000
signum opel turbo the gear problem
vectra v6 cdti loss of power
where is the maf sensor located on a 2006 vectra c 3.0 v6 cdti
