Thread: another heater motor fault!
    Hunwick, County Durham.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    Default another heater motor fault!
    today i turned the heaters on and front demister. it went off within 3-4mins of driving off. its been raining and the passenger footwell is wet. i have done the pollen filter drain for the third time in a year, this is the only time its flooded through.
    i have taken the glovebox out and looked at the resistor pack, its got a slight bit of corrosion on the top but it seems fine. if anyone knows a test to prove its good i would appreciate it.
    the big thing worrying me is when i took out a screw in the bottom of the heater motor i got a small amount of water out, around 15-20mils.i think its shorted something inside. all the lights on the heater controls work and i can hear relays clicking when the fan control is set to position 1,and 4, and when the front demister is turned on another relay clicks.
    does anyone know how to remove the heater?
    any info is greatly appreciated.
    cheers, mick.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    Does anyone have any tips on removing the heater motor as I can't find much about it online or on here? Or a link to removal/fitting?
    Cheers, Mick
    playing with spanners
    Did mine the other day
    Remove glovebox, thers one screw that holds in the plastic tube to put air onto your feet remove the screw and the tube will put out, remove the wireing plug that goes into the motor, there is 3 clips that tou will see holding the motor in along with around 10 screws then it will pull out with a bit of twisting, took me a couple of hours to do mine because I didn't have the right tools
    To get to all the screws out you will neet to use a flexi screwdriver.with a torx on the end
    Any problems just pm me
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    cheers for that mate. i just confirmed it as the heater motor. put 12V across it and nothing, gutted!
    bigron1988 where did you get your motor from and how much did you pay? im going on the hunt for mine today from a scrapyard and dont wana be ripped off.
    cheers, mick.
    I bought mine of ebay, came out of a 08 plate car, came with the resistor for £55 delivered
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    well it cost nearly £200 for the heater motor and pollen filter. i managed to change the heater motor in around 45mins, old one out and new one in. cheers for the help with the replys.
    mick.
  1. Heater Motor
    By barnes61 in forum Electrical & ICE (including SatNav)
    Last Post: 29th December 2011, 17:46
  2. heater fan motor
    By bigron1988 in forum Electrical & ICE (including SatNav)
    Last Post: 28th January 2010, 20:08
