Thread: Removal of Steeringwheel, Veccy 06 facelift
    May 2007
    Norway
    Default Removal of Steeringwheel, Veccy 06 facelift
    Hi
    I'm thinking of replacing my original standard steeringwheel with an OPC-one, but wonders if it is a troublesome task to do...
    What first strikes me is the removal of the airbag; Is this screwed on or held just by clamps? How is it then released?
    I assume that the steeringwheel then is attached to the column by a center-bolt, so that should be straightforward.
    Any known problems related to removel/attaching the steeringwheel, etc to look out for?
    Cheers,
    Hirobofly
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    As scary as it first seems removing the steering wheel on a Vec C is unbelievibly easy to do. Just make sure you disconnect the battery and give it a chance to discharge any power left in it
    May 2007
    Norway
    Thank you for the info, guys!
    - I wonder why that HowTo did not show up in my search for Steering wheel, but thanx for the link Penfold101.
    Looks like an an upgrade of my steering wheel is to be done shortly.
  1. steeringwheel with exclamation mark
    By nadeem69 in forum Electrical & ICE (including SatNav)
    Last Post: 9th October 2012, 21:00
  2. Just fitted my irmscher steeringwheel
    By Hummelshøj in forum Styling
    Last Post: 21st March 2011, 21:55
  3. Leather Steeringwheel + Airbag Module ...
    By hans_vledder in forum Parts for sale
    Last Post: 26th May 2008, 09:11
  4. new veccy facelift look
    By andy.l in forum Styling
    Last Post: 5th March 2006, 21:46
