Results 1 to 10 of 13
Thread: Water in headlights
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Default Water in headlights
    Quite a few people have mention recently that the headlights either mist up or like mine turn into water carriers .
    For those of you who like me would prefer to know where there going at night time i have enclosed some pics of how i dried out my headlight using a hair dryer.
    initially when i removed the headlight unit it contained enough water to fill a small wine glass but i stil,can not seem to be able to find how the water gets in there in the first place.
    Just something else to keep us amused during the long winter months.
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    since ive put my HIDs in ive got the same problem ...
    dried them out once ....but bk again ...........
    further investigation taking place at Mattys on sunday with Dean in attendance
    going to get headlights off of car and make sure the seal around the gromit is air tight ,and also ck the seal of the headlight its self
    Engine : 2.0DTi
    Mileage : 73350
    I just wonder if the rubber boots expand from the heat when the lights are on and let the water in
    Regular Member leonvectrac's Avatar
    south shields
    i have it on one of my headlights, i also dryed it out using hair dryer and thought that would be that a couple of days later its back again am really sick of it. so think its gona have to come off, dry it out again then i mite try and seal it all round with clear silicon.
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    mine too have started fogging since i'v put in my hid's tried the silica gel packs but not much good
    Apr 2009
    norwich
    Quote Originally Posted by soulman View Post
    i have the same problem on my facelift,since i fitted hid,s to the main and high beam,used silicon to seal the grommet,and fitted a small silica sachet in the bottom vent seal,anyone got any idea,s ????
    Regular Member antowns's Avatar
    Nov 2009
    Amble, Northumberland / Ryton, Gateshead
    ill join the club i have the same problem too drivers side its really annoying
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    Could it be, just the moist air getting in when you change the bulbs & it getting trapped inside
    I know after the dealer repaired my AFL lights in winter a couple of years ago mine started to mist up
    So in summer i too got the air-dryer out, took out the main beam bulb out & give it a good hot blow inside & had no problem since
    20 Post(s)
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    Quote Originally Posted by boyce745 View Post
    and it still fogged up after youve done all that ????
    Full Member Robsey's Avatar
    North East Cheshire
    24 Post(s)
    Trim : Energy
    Mileage : 131,000
    Simplest option is to carefully drill a couple of small drain holes in the lowest part of the headlamp casing...
    This will serve two functions...
    1) allow water to drain out,
    2) prevent moist air being trapped in there,which should reduce steaming up.
  1. What colour is your radiator water bottle water? and head gasket.
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 21:39
  2. water in my headlights...preface lift
    By peteh in forum Bodywork & Interior
    Last Post: 29th October 2010, 21:54
  3. water
    By ade in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2008, 14:20
  4. Oil In The Water
    By VauxVeteran in forum Engine & Drivetrain
    Last Post: 6th July 2007, 17:45
  5. oil in the water (PLEASE HELP)
    By steve.davies in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2007, 23:17
vectra c headlight water
water in vectra c headlight
