Thread: bug & tar spot remover
    Regular Member TopRod's Avatar
    Liverpool, UK
    Question bug & tar spot remover
    Since I bought my silver lightning vectra I can't keep my eyes from vearing towards the many tar spots plauging the all the sills. I'd like to spend a day getting rid!!
    What is a good product to use?
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Quote Originally Posted by TopRod View Post
    Autoglym's - V.good.
    Liverpool, UK
    Quote Originally Posted by AntSSSS View Post
    Is it just called auto glym bug, tar remover?
    Middlesex
    Trim : SRI
    Mileage : 100k
    Cambridgeshire
    You can use some chemical guys stuff to to let it soak in when blast off with the pressure washer.
    However, nothing gets rid of tar like claying VERY easy to do and will take off all your tar spots without damaging the paintwork.
    Liverpool, UK
    Are you meant to use the tar remover and then use the clay to finish? It says its a detailer
    Cambridgeshire
    Nope you can just clay it.
    When you clay your car (the whole car) you spray on clay lub and rub the bar on the car where the lube is, keep doing this all the way round the car and keep needing the clay along the way.
    The clay picks up all the particles and tar that is stuck to the paintwork and holds it in the clay. It does this safely without damaging the paintwork.
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    Autosmart makes one and it will shift anything and you can buy 500ml bottles of it on Ebay.
    http://cgi.ebay.co.uk/Autosmart-Tar-...item3359a9d955
    Pebrokeshire
    AG is useless, you will def be there all day using this, do the decent thing and order yourself some TARDIS from Autosmart, this is amazing stuff. Aslo get yourself a claybar and use this after the Tardis over the whole car.
    I would not just use a claybar before removing any larger bit of tar, if you do this you will only drag a big lump of tar around with the clay, you must remove larger bits of tar with Tardis first then only use clay to remove the minute particles from the paint.
    Jan 2008
    NW - Cheshire
    Try WD40 sprayed liberally on a rag, worked wonders for me!
  1. bug and tar remover
    By vinty firth in forum Detailing and Car Care Discussion
    Last Post: 13th July 2012, 13:58
  2. tar remover
    By andy.l in forum Detailing and Car Care Discussion
    Last Post: 7th January 2012, 20:59
  3. best bug/tar remover?
    By paul_sri150 in forum Detailing and Car Care Discussion
    Last Post: 24th September 2010, 23:19
  4. tar spot remover
    By neverlandandy in forum General Chat
    Last Post: 8th August 2008, 17:16
  5. tar remover?
    By Gregg in forum Detailing and Car Care Discussion
    Last Post: 20th June 2008, 23:08
