Results 1 to 10 of 19
Thread: Changing CDTi Fuel Filter...
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Default Changing CDTi Fuel Filter...
    Found this post and it sounds quite easy...
    http://www.vectra-c.com/forum/showpo...09&postcount=2
    ..to those that have done this themselves, is it as described..??
    Cheers in advance
    Pretty much mate. I could not figure out how to get it out of the crash box and the lid was tight as hell, but a hammer and screwdriver eventually shifted it... No issues with bleeding as stated, just make sure the filter gives a good seal and is seated properly as mine leaked everywhere to start with...
    Lancashire
    Trim : XP1
    Mileage : 66000
    Good to hear, did you change yours in-situ then..?
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Yip - so basically.
    Remove the top two fuel hoses by pressing in the catches with a small flat blade screwdriver - you will see what I mean when you see the hose connections - no problems
    Remove the top elec connector
    Lift the cannister out of the holder. You will find it set in there quite well - so put your hand underneath and push it out
    Remove the electrical connector from the bottom
    Once out the car - undo the drain on the bottom of the cannister and drain the diesel out
    Now the only tough bit - remove the cannister top.. I did this by trapping the cannister in a workmate between two pieces of metal, then with a pair of oil filter pliers undid the lid. Be patient and you'll be fine - but you will need a set of oil filter pliers or the likes as you just cant get the turn by hand (well I couldn't as mine (and chrisvectra's) was very tight)
    Once undone - remove filter and tip out excess diesel.
    re-assemble in the reverse order.. Be sure to use the new seal that comes with the filter - and that its sitting correctly on the cannister. Take note of where the old one sits before you completely remove.
    When you re-attach the top two fuel hoses - make sure the clips clip back in properly.
    once all re-assembled - switch the ignition on and off three times leaving the ignition on for 10 seconds each time - this is enough to self bleed the system
    Job done..
    Middlesex
    Trim : SRI
    Mileage : 100k
    Do not try and open the lid in situ - you will crack the casing... trust me
    Erm, yes, mine was in situ... Needed a hammer and a pointy thing to undo it, but I couldn't for the life of me get the casing out of the crash box so I didn't have much of a choice...
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by Penfold101 View Post
    Lucky lad
    Hammer and screwdriver...... double lucky lad
    You have to get your fingers under the crash box and push the cannister up..
    Quote Originally Posted by AntSSSS View Post
    Lucky lad
    Trust me I tried everything with it mate, it wouldn't budge... It worked either way...
    Middlesex
    Trim : SRI
    Mileage : 100k
    Jobs a good-en then
    Lancashire
    Trim : XP1
    Mileage : 66000
    ** SILLY QUESTION ALERT **
    I assume the filter is the bit at the top of the engine bay, pretty much smack in the middle..?
  1. Changing fuel filter
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2011, 16:28
  2. HELP!! after changing fuel filter
    By williamM in forum Engine & Drivetrain
    Last Post: 30th December 2010, 17:49
  3. 1.9 CDTi - changing fuel filter
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2009, 11:22
  4. changing the fuel filter on a DTI
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2009, 12:30
  5. Changing Fuel Filter
    By CDTi-SRi-Matt in forum Engine & Drivetrain
    Last Post: 8th February 2009, 17:36
