Thread: Thermostat change - do i need to bleed?
    Oct 2007
    Scotland
    Default Thermostat change - do i need to bleed?
    Planning on changing the thermostat on my 150 and have read that you need to bleed the coolant system after it but I cant seem to find out how this is done. Can anyone enlighten me and possibly point out anything that I need to look out for?
    Do I need to remove the battery? If I do will the radio lose its code?
    Jan 2008
    Telford
    Unknown about the battery, but with the 2.0 DTi I know the cooling system self bleeds. Can usually tell if there is a breather pipe above the return pipe attached to the coolant reservoir.
    11 Post(s)
    Quote Originally Posted by Tigger View Post
    If half canbus, yes. Full canbus, no
    Half can - 6 buttons on the steering wheel.
    full can - 4 buttons and 2 scroll wheels.
    Don't forget to reprogramme the windows. Fully open, then hold button down for approx 5 seconds, then fully close, and hold finger on button for approx 5 seconds. Repeat for the other windows.
    As regard bleeding, any air should return to the header/expansion tank. That's why it's the highest part of the cooling system.
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    Will post up the correct bleeding prodedure as stated by the tech guide when i get home tonight....
    Oct 2007
    Scotland
    Cheers for the info on the battery. Mine is full canbus so it is just the windows to deal with. (Wouldnt have guessed that).
    Plasma, appreciate your help.
    Another questions I'm afraid - I see that you lose approx 2.5 litres of coolant. What mix do I put back in? How much Antifreeze to water?
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    As promised. Vx guide to cooling.. No need to disconnect battery but on the tech guide it does say to 'remove' the battery altogether to give better access to the spring clips on the hose pipes... although i didnt..
    Important: Vehicles with AC: Switch off air conditioning or with ECC set to ECO Mode (if available)
    1. Open cooling system
    Warning: Cooling system is under pressure.
    • Unscrew the coolant expansion tank cap.
    2. Top up coolant; open bleed screw on coolant distribution pipe until coolant flows out
    • Coolant compensation tank
    Important: If the cooling system (including heater) is completely empty, overfill the coolant compensation tank up to the filler neck and open quick connector in heater feed line (left in direction of travel) and bleed screw of coolant distribution pipe (above exhaust manifold) until coolant flows out.
    • To marking KALT/COLD
    3. Close cooling system
    • Close cover of coolant compensation tank
    4. Start engine and allow to run
    Note: Operate engine with the following cycle 1 x: 30 seconds – 2000 rpm to 2500 rpm, 5 seconds idle speed, 30 seconds – 2000 rpm to 2500 rpm.
    Allow engine to warm up at idle speed until the 1st radiator fan stage is also switched on.
    Operate engine with the cycle above again 1 x
    Cooling system bleeds automatically during engine warm-up phase.
    5. Switch off engine
    • Allow engine to cool
    6. Check coolant level.
    Note: To marking KALT/COLD – top up coolant if necessary
    Lastly, I used a pre-mixed antifreeze so no need to think about it
    Oct 2007
    Scotland
    Good man Plasma, Thanks very much.
  1. thermostat change
    By vectra-man in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2013, 13:47
  2. thermostat change
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2012, 12:52
  3. thermostat change
    By smartalec0310 in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2012, 17:54
  4. Do i change my thermostat?
    By beggsy in forum Engine & Drivetrain
    Last Post: 26th May 2012, 10:59
  5. How to change a thermostat 2.2
    By vx sri in forum Engine & Drivetrain
    Last Post: 22nd March 2011, 22:05
how to bleed coolant on vectra c www.vectra-c.com
opel astra 2.0 bleeding of cooling system
