Thread: resetting ecu spanner
    newcastle
    Default resetting ecu spanner
    i had spanner light on and eml on cleaned egr a maf so how do i reset computer or do i need to take it to vaux
    Regular Member r.bailey63's Avatar
    Mar 2007
    Stockton on Tees
    If you fancy a drive down to Teesside i will do it for you.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    If the fault has been resolved I believe the code will clear after 25 engine starts.
    Gazza4
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    What made you clean the EGR and MAF? Did you get the fault code(s) read?
    newcastle
    thanks for offer will consider i cleaned because i got code p0111 hoping it was these two but not sure now cos eml on again going to disconnect battery and see if that resets computer what else can i check im at a loss
    Mar 2007
    Stockton on Tees
    Will probably need the codes reading and clearing to turn it out.
  1. what does resetting the ecu do
    By justin32 in forum Engine & Drivetrain
    Last Post: 6th January 2013, 23:12
  2. key fob resetting
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2012, 20:48
  3. Abs resetting
    By jodiexii in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2012, 12:05
  4. Resetting the ECU
    By kamar in forum Vectra C / Signum Car Chat
    Last Post: 27th July 2010, 12:49
  5. resetting the ecu
    By lee_eardley in forum General Chat
    Last Post: 6th September 2007, 11:55
