Thread: Fitting a Tuning Box
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Default Fitting a Tuning Box
    I want to get a tuning box for my 1.9 CDTi (120).
    But first I would like to know how to fit it.
    Think I will be going for a Digital box.
    Ive heard its a bit tricky on the 120s??
    Anyone got any pics??
    Thanks,
    Mark
    Regular Member jonno_07's Avatar
    Apr 2006
    beverley
    it is a bit tricky the first time yu do it but it gets easier.
    pics to follow!
    Apr 2006
    beverley
    take off top cover (when engine is cold! i burnt myself) disconect the ecu wire and put the new wire in! its quite fiddly but once you've done it once it gets easier!
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Disconnect the plug going onto the common rail (long silver cylinder) and then plug the loom in.
    Don't disconnect the ECU!!!
    Apr 2006
    beverley
    thanks cdti thinkng of too many things at once!
    sorry marky!
    Jun 2006
    North West
    Soooo is the cable circled the ECU cable or the Common rail cable??
    I know I should get instructions when I finally plump for a box. I am just too impatient!
    Apr 2006
    beverley
    its the common rail picture just me sayin the wrong thing! the connection is just under where the two pipes in the pic meet!
    pm sent.
    Jun 2006
    North West
    Should be able to find the plug for the common rail now, Thanks.
    But I now need to find a Switched Ignition 12V power source in the engine bay for my Tuning box. Anyone know where is best to get this from??
    Heres the box I bought. £150 from mrhoot on eBay. Bargain!!!
    [IMG]http://www.vectra-c.com/forum/upload...20Box%20SM.JPG[/IMG]
    'Norf Yorks.
    You sure it is switched? I fitted one of those VERY simular to a VW and it wanted permanant live.
    Put it this way, fitted 8 months ago and wired to permanant live and no flat batteries. I would of thought permanant live would be fine
    Jun 2006
    North West
    You can have it permanent or switched.
    If its switched you get these cool features.
    1). The box can set itself to only work after a preset time (ie when the engine is up to temperature).
    2). You can use switching the igintion on/off for a preset number of seconds to start the box, so only people who know the ignition sequence can use the extra power every one runs the car as standard.
  1. Problem fitting tuning box
    By 2.2 oil burner in forum Diesel Engine related
    Last Post: 5th December 2010, 20:15
  2. Vectra tuning box fitting help
    By shug176 in forum Diesel Engine related
    Last Post: 20th September 2010, 02:25
  3. Problems fitting a tuning box to the 120.
    By felixx in forum Engine & Drivetrain
    Last Post: 19th July 2010, 21:05
  4. Fitting Eco Green Tuning Box
    By RMJonny in forum Engine & Drivetrain
    Last Post: 17th July 2010, 11:15
  5. Fitting tuning box for 120 cdti
    By Rick106 in forum Diesel Engine related
    Last Post: 27th March 2006, 17:47
