Results 1 to 10 of 23
Thread: EGR Symptoms re-ocurring after new EGR fitted...
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Default EGR Symptoms re-ocurring after new EGR fitted...
    Just had a text from my mate who we fitted a new EGR valve to his CDTi 150 a couple of weekends ago - for the week after fitting it the car ran perfect, no lumpyness, power from anywhere in the range, the engine lost its loud clatter etc... but in the last few days he says its been getting worse and now is as it was before we changed the EGR.
    Has anyone heard or had this before, what did you do to remedy, after ideas before we have another look.
    BTW, the car has had a new inlet manifold recently and has the blue injector plugs already.
    Cheers in advance.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Apparently the reconditoned ones (ones that have been fixed with the help of the How2) actually work better.
    Gazza4
    Lancashire
    Trim : XP NAV
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    Better than a brand spanking new one...?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Yeah, mines does and its reconditioned plus there is a 3mm hole for me to spray grease into - as it is corrosion/lack of lubrication of the solenoid that prevents the egr valve functioning properly.
    Gazza4
    Lancashire
    Trim : XP NAV
    Have you had a new one in yours before...??
    leicester
    im having the same trouble jus had a new inlet manifold egr and it seems mine is playing up hardly any power untill turbo kicks in ive only had it done just over 2 months ago any suggestions
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    No i have heard a few stories like the one you describe and the one in mines cost me £35 from someone who had a spare, but that is a bargain compared to a new one at £107+VAT.
    Gazza4
    Cambridgeshire
    I put a brand new one on mine and it's been fine ever since mate. I changed it back in June and then put the restrictor gaskets on in November. Car seems fine still can't wait to fit the other restrictor gasket to see if there is a difference
    Lancashire
    Trim : XP NAV
    New day bump....
    Could it be that we didn't clean the opening on the inlet manifold much (to be honest we didn't do much with it)... could this cause this.
    What else can cause these symptoms..? Air leak, MAF fault..?? etc.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Mate - if it helps after I had my inlet changed which included software and EGR - was fine then for about 1 month - then lumpy idle and very hesitant, fix; new Injectors which fixed the above.
    Would be worth giving it a good clean out with brake cleaner and the inlet opening too..
    Also - clean the boost sensor, another 5 min thing that can make all the difference..
  1. P0100 most likely cause for these symptoms
    By brotherkennyh in forum Vectra C / Signum Troubleshooting
    Last Post: 16th November 2012, 22:16
  2. PIgflu symptoms?
    By Dose in forum Comedy & Humour
    Last Post: 1st May 2009, 22:08
  3. EGR symptoms
    By tobybongo in forum Engine & Drivetrain
    Last Post: 12th October 2008, 21:32
  4. dmf symptoms
    By tommy tess in forum Engine & Drivetrain
    Last Post: 30th May 2008, 21:14
  5. Symptoms Of Being Over 25…..
    By Inspektor in forum Comedy & Humour
    Last Post: 22nd February 2006, 15:47
