Thread: CID type confusion
    Regular Member yzf1kr's Avatar
    Netherlands
    Default CID type confusion
    I am confused about all the CID types around.
    I tried searching on CID but the only 3 characters is to short for a search.
    I would like to upgrade the GID on my pre-facelift full canbus vec with CD70 to a CID, I have been looking on Ebay but I see many types.
    I remember a thread that said that I need type BD for my car, but only types I can find are BN and YF.
    Is there a list somewhere on this forum of all the types and what wil fit what car?
    Full Member Robsey's Avatar
    North East Cheshire
    20 Post(s)
    Trim : Energy
    Mileage : 131,000
    I am compiling a list, but for pre-facelift full can CID you will need:
    AK - 132 06 564 or 12 36 753 - chassis number 71000000 to 71082921
    or
    DB - 244 612 93 or 62 36 485 - chassis number 51000001 to 71000000
    You will also need rgb cable - code RTZ - 131 854 91 or 62 94 476 - called " Aux Display Harness".
    AW is a wide screen / facelift item for chassis number 71082922 onward
    ER, GQ, QY, WY, YF & YG are all variations on half-can colour screens and so are also unsuitable. for vehicles upto chassis number 48999999
    hope that helps....
    Netherlands
    Thanks ,
    This does help a lot.
    Any idea on what the difference is between the AK and the DB version? I need a DB, but what if I fit an AK?
    Also, I see some people fitted the widescreen version, by replacing the vents. Can an AW be used?
    North East Cheshire
    20 Post(s)
    Trim : Energy
    Mileage : 131,000
    AW can be used...but it is from a facelift vectra. It is also a widescreen display.
    You would need a facelift air vent panel...approx £40 from Vauxhall.
    Then you would need to grind the top 3mm ( 1/8th Inch) off the top to remove the curved profile along the top. so that it fits into squarer profile of the pre-facelift dash panel.
    You will also need to ensure that it is pushed up when you screw it back, or else the clip-in trim strip (that runs from the top of the glovebox to between the radio and screen) will not go in underneath it properly.
    I did this for the wife's 2005 vectra with a 2006 CD70 and CID.
  1. SMD confusion
    By MattVecVXR in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2013, 22:01
  2. DPF confusion.
    By JayF in forum Engine & Drivetrain
    Last Post: 7th April 2012, 10:00
  3. TID & GID confusion
    By RobW in forum Electrical & ICE (including SatNav)
    Last Post: 20th April 2010, 18:28
  4. HID Confusion :(
    By antowns in forum Vectra C / Signum Troubleshooting
    Last Post: 7th February 2010, 19:11
  5. HID confusion
    By parsco in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2009, 15:08
