Results 1 to 10 of 16
Thread: Courtesy light button not working.
    Fife
    Default Courtesy light button not working.
    Does anyone have any ideas how to fix a courtesy light button that doesn't work. the bulbs are working because the light comes on when the doors are opened. 2.2 DTI Sxi.
    Cheers.
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    New courtesy light?!
    Full Member Big Sig's Avatar
    Fife
    Cool, cheers guys.
    Fife
    UPDATE:
    Ok, bought new light unit, the 4 button one with map reading lights, and the problem is still there.
    The light comes on when the doors are opened or key taken out of the ignition and can be canceled with the bulb button but the light will not turn on with the power button. The map reading lights don't come on either.
    Could the problem be with the light sensor thing that clips into the light unit as I just used the old one.
    Any ideas welcome!
    Mar 2007
    Southport
    There must be a permanent live feed to the light which isn't live - check the fuses & connections
    Hanging Heaton / Batley
    21 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Are the switch buttons themselves lighting when turning on your dash lights on etc?
    If not - open then Close your door while sat in the car... and with the interior light on due to the doors opening, press the ON/OFF button repeatedly and see if the buttons lights up and off with the interior light
    If they do, but then dont work once light itself goes off its definalty your ribbon...
    I've nicked mine somewhere fitting a rear light and i get the above issue... £50 from the stealers...
    Fife
    The buttons do not light up, but I don't think they are supposed to as they are just grey plastic with the icons printed on them. Discovered though that all the buttons work as they should and the reading lights operate while the delay is on after opening/closing the door. Problem is that after the delay of 15-20 seconds after the door is closed the light goes out and the buttons do nothing until the door is opened or key removed from ignition.
    Thinks its gonna be a visit to Vx
    Full Member Robsey's Avatar
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    If you have buttons with symbols on, then they "should" light up.
    Is there anything else that doesn't light up?...Is your radio display affected by the light going on and off?...
    First port of call, check the fuses in the fuse box at the end of the dash...these are for the BCM supply, which disributes all lighting functions.
    Check especially Fuses F7, F9, F12 and sometimes F4...better still check all of them to be on the safe side. F4 may not be present...it isn't always as Vx change wiring functions and configurations for fun.
    21 Post(s)
    Mileage : 110k
    Quote Originally Posted by Robsey View Post
    Could it be a fuse with mine then?
  1. Radio on/off button not working
    By sriandy in forum Vectra C / Signum Car Chat
    Last Post: 20th July 2012, 15:03
  2. Courtesy light
    By mikey362 in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2012, 01:52
  3. Lock button not working
    By frigosolver in forum Electrical & ICE (including SatNav)
    Last Post: 18th March 2012, 22:57
  4. Recirc Button not working
    By Knight Rider in forum Electrical & ICE (including SatNav)
    Last Post: 3rd October 2011, 16:57
  5. Courtesy light
    By peter142 in forum Bodywork & Interior
    Last Post: 11th June 2007, 23:07
