I have a CD70 Opera unit with DAB, but what can I do to get the the full BC? Currently when I press the button the only option I get is the timer...
Also, would I be able to add an Aux-in plug to this unit?
To get BC working, you'll need a tech2 session.
I didn't think however the CD70 had DAB? Mine doesn't, and I've not seen reference to it anywhere other than your post.
Hmmm, I'm sure it's a CD70... maybe it's a CD40 then - does that make more sense?
Yep, Opera is a CDC40 with optional DAB.
It also has an in-built CD multi changer
CD70 is a "Navi" item with a music CD slot at the top and a CD rom drive for maps at the bottom.
If BC is not working, then it wil need a Tech 2 programming session to change the "Variance" and "Code Index" settings.
Yeah, that must be the one then!
How much would VX charge for this?
