Thread: Heated Washer Jets ??
    Sep 2009
    egypt
    Default Heated Washer Jets ??
    i have Heated Washer Jets in my Vectra 2008 but i don't feel that the water jet heat the water!!! , Does the washer jet heat the water in any case or when it is cold??!!!! (Temp. < 0)
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Think you have to switch on the rear demister for these to work
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    As above. They are not really to heat the water so that you get warm water coming out, but merely to prevent freezing of water in the jet itself which would stop them working.
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Quote Originally Posted by Ste View Post
    Does it work? Aren't the pipes just as likely to freeze?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    the jets are more likely to freeze before the pipes.
    but it also depends on your screenwash..
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Quote Originally Posted by lofty View Post
    Definately not the case on my 02 GSi. Otherwise, if you were on the motorway at say -5 degC with the all the windows clear cos the a/c is on, why would you have to put the rear screen heater on just to get heated washers?
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Does A/C activate at that temp? And the heated front jets ARE powered when heated rear screen is on.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Just put a meter across the two wires on my jets with the engine running, no rear demist. Result = 12.9 volts across the wires.
    Why wouldn't the a/c work at - degC. Off topic, but can you explain?
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I thought it didn't work when low ambient temp. The air would be so dry anyway, that I doubt there would be much benefit anyway.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    My compressor churns away on very cold mornings when the temp dial is set to 28 degC. The a/c still works as it's conditioning the air and as far afaik, a/c works over the whole temp range, ie. 16 to 28 (or "max") degC.
  1. Heated washer Jets :D
    By GazVXLINE170 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2010, 00:59
  2. heated washer jets
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2010, 22:35
  3. heated washer jets??
    By mitch in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 22:54
  4. Heated Washer jets
    By jamesworts in forum Parts for sale
    Last Post: 31st December 2009, 15:30
  5. heated washer jets
    By kpf1grandprix in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2008, 16:30
