Thread: standard lowering
    N E Somerset
    Default standard lowering
    According to Parkers test report on the Vectra C SRi at a certain point the lowered/stiffened sports suspension was apparently a no cost option. Has anyone seen an SRi without sports suspension?
    Is the lowering 20mm compared to standard i.e. same as it was on the 'B' SRIs?
    [Ex]Admin Duncan's Avatar
    I've always been under the impression that all SRi Vec C's had the sports suspension as standard from the start.
    Yes, it's 20mm lowered.
    Regular Member Matt21385's Avatar
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Does the GSI use the same suspension as the SRI?
    Regular Member ope126's Avatar
    May 2006
    Brisbane, AUSTRALIA
    Also, when people change the OEM 17" for say 18" or 19" wheels are you lowering the car futher, or still utilising the "Standard" lowered suspension?
    N E Somerset
    That's what I thought. I'll try and post an image of the Parkers options list tonight for your consideration.
    GSi should be the same as far as lowering and uprating goes except that the front springs (and possibly dampers) might be different to take into account the extra weight of the V6 (at least that's how it worked on the V6 'b's).
    No, changing the wheels size doesn't have any effect on lowering, suspension wise. It would physically lower the car a little if you changed the overall rolling circumference by changing the profile of the sidewall on the tyres.
    Jun 2006
    Lake District
    Vehicle : Vauxhall Insignia
    Engine : CDTi 160
    Mileage : 53.000
    All SRi's will have the suspension...well, from new anyway, probably a few s/h ones about that some daft@rse has swapped it for standard kit.
    They introduced the lowered/uprated suspension in the early Vectra B SRi
    N E Somerset
    Here is a list of the options as promised for your consideration
    N E Somerset
  1. standard setup on sxi, standard or sri?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2012, 02:30
  2. Lowering on standard shocks
    By yoclick in forum Handling & Braking
    Last Post: 18th January 2011, 15:52
  3. Lowering Springs on Standard Shocks
    By bizerk in forum Suspension, Wheels & Brakes
    Last Post: 14th March 2009, 01:51
  4. lowering on standard shox
    By kev bux in forum Handling & Braking
    Last Post: 30th June 2007, 17:57
  5. standard sri lowering springs
    By j1 wyx in forum Parts for sale
    Last Post: 30th May 2007, 22:40
