Thread: Adding Fogs to C Facelift
    Wolverhampton
    Default Adding Fogs to C Facelift
    I have a VCFacelift, rear fogs, but no front fogs. I can get the surrounds no doubt and the lights themselves, but being the Facelift, does it already have wiring ready behind the bumper?
    I dont want to go to the trouble of buying the parts, taking the bumper off only to find there is no wiring.
    Dartford
    Take you ten mins to whip front bumper off... Go have a look
    Blantyre
    Wolverhampton
    Well then I'm just doing exactly what I didn't want to lol. Are they fiddley to get back on?
    Full Member Robsey's Avatar
    North East Cheshire
    24 Post(s)
    Trim : Energy
    Mileage : 131,000
    Bumper is very light and easy to remove.
    Light switch is about £45
    Fog-light trims are about £5 per side..
    Fog lights themselves, don't know, got mine from e-bay for about £5 a few years ago.
    You should be okay if wiring is all present...the fog light loom will run along the front of the chassis, behind the radiator grill / trim, but in-front of the radiator.
    Look for the temp sensor in the middle of there...the fog light loom includes the wiring for the temp sensor, so you should be able to trace the loom to both bottom corners.
    By the way, my 2005 Vectra had the loom, but the wrong Under Hood Fuse Centre...it could not be re-programmed (Tech 2'd) to enable the foglight function.
    I ended up doing it the old fashioned "via a relay" method...if yours is the same, then look at the how 2 by Armoured farmour.
    Wolverhampton
    Iv had a look and its wired, Just need to get some trims and light and im off!
    North East Cheshire
    24 Post(s)
    Trim : Energy
    Mileage : 131,000
    And tech 2 / op-com programming to enable function in the UEC variance coding
  1. Vectra - adding front fogs
    Last Post: 3rd June 2012, 23:38
  2. Pre-facelift SRI/GSI fogs, who makes them??
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 28th June 2007, 21:00
  3. Facelift Signum Fogs & Facelift VXR Front Splitter
    By 3.2_V6_VXR in forum Parts for sale
    Last Post: 6th May 2007, 19:30
