Results 1 to 2 of 2
Thread: Done the search, lubing/greasing EGR Valve soleniod
    Aug 2009
    herts
    Default Done the search, lubing/greasing EGR Valve soleniod
    Hi chaps
    Done the egr solenoid drill tap and replace. Used a lubricant I had to hand (no not that one!)
    It is slowing again, I believe the lube (again, not that one!) has dried out.
    What is the best lubrication/grease for the solenoid pin to run at its best movement/condition please?
    I'll take it off at the weekend, put on the best suggested lubrication and and the same time fit my fiat gasket on too.
    Thanks for your anticipated help
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    I only sprayed mine with loads of WD40, and it's been fine for over a year now.
    I guess if you're having real problems with it drying out, a good molybdenum disulphide grease would help, that's if you could get it on the whole thing properly which might not be possible. Good thing about moly grease is it continues to work when/if it dries out.
    But, it's very thick stuff - not sure it'd be suitable really :/
  1. Car PC Search
    By JSYSH466Y in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2009, 18:23
  2. EGR valve after doing a search
    By robhullfury in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2008, 18:09
  3. In search of...
    By heaton_uk in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2007, 16:40
  4. Copper greasing brake pads
    Last Post: 22nd July 2006, 21:25
