Thread: Is this normal.....oil in the air filter intake
    Regular Member killer_bunny's Avatar
    Jan 2010
    leeds
    Default Is this normal.....oil in the air filter intake
    Just done the airbox mod this evening and fitted the K&N. When i took the pipe off that connects the airbox to the engine i noticed some black runny substance, looks very much like oil on the airbox side of the butterflys. Is this normal?
    Pic here...cheers
    http://www.facebook.com/photo.php?pi...4&id=512305573
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Sort of normal but not as bad as my GSI was when I first noticed it.
    Caused by the breather pipes that come from the rocker/valve/camshaft covers and maybe, the crankcase ventilation pipes.
    Chances are it's never been cleaned out. Use a bit of carb cleaner to clean it up and check it again in say 1000 miles.
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    is it a diesel engine? if so its quite normal. It comes from the turbo seals. Every turbo car i have owned is the same. Might be an idea to clean the butterfly though
    Jan 2010
    leeds
    its a petrol v6 petrol with 137000 on clock. ive give it a wipe with kitchen roll lol! wipe butterfly too but was burnt on. have i to remove butterfly completely to clean?
    Jan 2008
    Dundee
    i would
    Jan 2008
    Dundee
    there used to be a product on the market called 20k boost iirc. You had to run the engine and spray the contents of the can into your intake whilst keeping the engine reving. Its ment to de coke everything without having to dismantle. I used it years ago and was impressed with the results.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by killer_bunny View Post
    This should help with removing the throttle body http://www.vectra-c.com/forum/showthread.php?t=35586
  1. K&N Air Filter on Vectra C Has Oil Sploshes ? Normal?
    By Elahi_786 in forum Engine & Drivetrain
    Last Post: 2nd May 2011, 00:40
  2. K&N Panel Filter & dbilas Air Intake Pipe
    By dae36 in forum Parts for sale
    Last Post: 23rd March 2011, 10:16
  3. Air filter intake upgrade
    By shan in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2008, 16:35
  4. BMC CDA filter / DBilas intake
    By Vid in forum Petrol Engine related
    Last Post: 16th June 2008, 20:55
