Results 1 to 10 of 16
Thread: Rear upper control arm
    Regular Member arniedavo's Avatar
    merseyside
    Default Rear upper control arm
    changed drivers side today after advisory on MOT
    when ive put all back together the ****** clunking noise is still there ??
    any ideas folks
    is it worth changeing other side even tho this seems ok ??
    thanks in advance
    merseyside
    thinkin it could be ARB bushes ??
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    Could well be mate very common
    Regular Member Jezzy's Avatar
    S.E
    Or the ARB droplinks.
    merseyside
    rear ?????????
    Regular Member suj786's Avatar
    glasgow
    I've been told my rear ARB droplinks (rear) need changed too,
    I never knew the vectra had them ???
    glasgow
    Quote Originally Posted by arniedavo View Post
    I had same problem last year mate,
    changed springs and control arms, rattle still there. (£200 odd)
    changed arb bushes (£30)
    noise gone.
    raging
    S.E
    rear ?????????
    Yup, the rear ARB has stubby little drop links, about 3-4" long.
    merseyside
    thanks for that
    rang local stealers and they tellin me there is 4 different size ARB bushes 16 -19 mm ??
    anybody no what a 2.2 dti sri 2003 model has or part number
    Nottinghamshire
    thanks for that
    I would think the dealer can tell from your reg. or suspension type (sport, standard, etc).
    If not, the size is printed on the outside end of the ARB's - you should be able to see it if you rub the dirt off and shine a torch on it. I have an Elite with standard suspension and my rear ARB bushes are 17 MM.
    Finding the correct size first was a preventative measure against being given the wrong ones by the dealer and only finding out when the car was in bits.
    I have a rattle and have already replaced the rear shocks and ARB link bars, so I'm assuming it must be these bushes so thery're next on the list.
  1. Rear upper control arm bushes
    By valleyboy in forum Suspension, Wheels & Brakes
    Last Post: 4th February 2013, 09:13
  2. Rear Upper control arms help
    By enjoy_life27 in forum Suspension, Wheels & Brakes
    Last Post: 15th January 2013, 23:04
  3. Rear upper control arm
    By GSiFan in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 11:54
  4. Rear upper control arm
    By STEVE S in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2009, 18:55
  5. rear upper control arms
    By Morephun in forum Suspension, Wheels & Brakes
    Last Post: 24th October 2008, 18:29
vectra c upper control arm wrong size
