Thread: lowering springs
    Sep 2009
    campbeltown argyll
    Default lowering springs
    found out today that my rear spring is broken, anyone recomend what kind to get want to keep it lowered 40mm also don"t wanna pay to much only looking to keep the car for another year or so!!!
    also i need a front shock so if you know anywhere to get one let me know!!
    cheers
    Sep 2009
    campbeltown argyll
    anyone????
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    You want to keep it lowered 40mm.... does that mean its lowered already..?
    If so, you will need the same springs as you have, other wise (if you WANT to lower it 40mm) then PI springs are what you need, but some have had problems with non-SRi shocks.
    Front shock..? Ebay, local scrappy, Eurocarparts etc....
    Regular Member woody in shetland's Avatar
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    Eibach's are good, i paid £150 for my set and that lowered her by 30mm i think it was, i'm a little confused though are you looking for an individual spring or a full set of 4, i'm not sure if you can get separate lowering springs.
    Regular Member kdadidog's Avatar
    county durham (peterlee)
    I would recommend the PI ones as I have them. But like its been said they broke my front shocks within 2 weeks.
    Sep 2009
    campbeltown argyll
    sorry its already lowered 40mm on koni springs i was just really wanting to get back 2 springs but if i get 4 i will just keep fronts as spares.
    also my front shock is fooked is a 2nd hand one ok to get aye??
    Lancashire
    Trim : XP NAV
    You'll need a spare Koni spring then, or a full set of others.
    Sep 2009
    campbeltown argyll
    could i put a diffrent set on the back bud and leave the koni on the front???
    Lancashire
    Trim : XP NAV
    Quote Originally Posted by colly View Post
    You could, but it wouldn't really sit level, and I'd be wary of differing spring rates between manufacturers upsetting the handling of the Vec.
  1. lowering springs
    By mvl41183 in forum Handling & Braking
    Last Post: 23rd December 2011, 23:20
  2. lowering springs
    By cockney16v in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2011, 14:56
  3. Lowering springs...
    By 19CDTi in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2011, 23:33
  4. Lowering springs
    By parsco in forum Handling & Braking
    Last Post: 14th September 2010, 21:50
