Thread: Servicing Vectra C CDTI SRI
    Jun 2006
    Newcastle
    Default Servicing Vectra C CDTI SRI
    Hello Guys
    Anyone got a guide on how to change the Oil and fuel filter on a Vectra C CDTI SRI?
    Tricky
    Oil filter How 2 - I did this for a 2.0T but the principle is obviously the same. The sump drain plug and oil filter location will possibly be different on yours.
    Fuel filter - what CDTi have you got? 1.9 (120 or 150) or 3.0?
    Jun 2006
    Newcastle
    Thanx Duncan
    I did have a look at your How 2 - Which is excellent by the way. but the Engine setup is different and I cant see the Oil filter as described....
    Its a 1.9 CDTi 120
    Tricky
    I don't know where the oil filter is on your engine, maybe another owner can help.
    Regarding the fuel filter change - this PDF should help you. I've stuck a bit on the end about draining water from the filter as you replace the filter every 2 years/20,000 miles and drain it once a year.
    HTH
  1. Servicing - 1.9 CDTi [150]
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 19th December 2009, 10:58
  2. 3.0 V6 CDTi servicing questions
    By James7 in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2007, 20:10
  3. 3.0 V6 CDTi Servicing
    Last Post: 5th November 2007, 07:01
  4. Vectra C 1.9 CDTi Servicing
    By RobW in forum Vectra C / Signum Car Chat
    Last Post: 15th September 2007, 12:46
  5. 1.9 CDTI Servicing
    By davyboy in forum Engine & Drivetrain
    Last Post: 7th June 2007, 11:33
