Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Restricting EGR flow may help turbo spool up 1.9 DTH
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    Default Restricting EGR flow may help turbo spool up 1.9 DTH
    I've just noticed on the picture below:
    http://www.vectra-c.com/forum/showpo...93&postcount=4
    The EGR take off from the exhaust is just prior to the turbo.
    Now the EGR opens allowing exhaust gasses through below 2000 rpm which in turn may starve the turbo slightly, just when you really need it the most.
    So by restricting the EGR or even better blanking it (TECH2 or certain remaps required to disable EML) would the turbo spool up faster at lower revs?.
    I have the restrictor plate between the EGR and inlet manifold, and a further restrictor on the inlet to the EGR (A stainless steel penny washer with an 8mm hole in it) and I can hear my turbo spooling up from around 1300 rpm and I have no flat spot and other members on here have also mentioned that their 1.9's seem to have better low rev performance.
    Could this be a double whammie?, less crud into the engine and better low range turbo response?.
    Please reply with your thoughts.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    That theory works on the BMW 2.0/3.0 D engines when the EGR is bypassed and blanked off (a must do mod on them) - surely must be the case with the CDTi.
    Has anyone totally blanked their EGR off..?
    I know the EML will come on, but how would it drive..?
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Its peeing me off that I cant even use the semi blanking Fiat plate without the light coming straight on
    Jul 2006
    Wolverhampton
    Quote Originally Posted by AntSSSS View Post
    Have you tried cleaning the boost sensor as this may be part of the detection for the egr if not it still helps having a clean sensor with the performance, an allen key and a bit of carb cleaner is all that it takes.
    Middlesex
    Trim : SRI
    Mileage : 100k
    oh yeah done all that at the weekend when i gave her a full service.
    had a new inlet which included new boost sensor and EGR valve.
    I've had all my software updated when I had the third injector mod and Inlet and some of the software updates were around EGR and pressures so possible that its made it more sensitive.
    Doesn't really matter TBH. Its been a year since new inlet and when I stripped off EGR and boost sensor to clean as part of a major service - they were in remarkably good condition (v-power diesel all the time and the odd "drive it like your ar$e is on fire" method probably helps )
    A
    Cambridgeshire
    Quote Originally Posted by Chocki View Post
    I have only restricted one side (EGR to inlet manifold) would you be able to tell me where you got the other restrictor plate from please?
    Lancashire
    Trim : XP NAV
    Quote Originally Posted by parsco View Post
    Fiat mate...
    http://www.vectra-c.com/forum/showpo...76&postcount=2
    These are for the CDTi 120 EGR though, I got one, but never had the bottle to try it on mine
    Middlesex
    Trim : SRI
    Mileage : 100k
    Yip - Fiat..
    And I only tried the large EGR to Inlet also. I have a spare one, if anyone wants to cover the cost of it - your welcome to it?
    A
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Yip - Fiat..
    A
    PM sent
    Cambridgeshire
    Quote Originally Posted by Ian S100 View Post
    PM sent
    Think I've beat you to it mate
  1. Turbo Spool with a 56mm Hybrid
    By nutron in forum Diesel Engine related
    Last Post: 16th December 2012, 16:25
  2. turbo spool
    By marc vectra sri in forum Engine & Drivetrain
    Last Post: 21st March 2012, 01:28
  3. Vectra 1.9 CDTI, cannot hear turbo spool up
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2010, 11:43
  4. turbo spool
    By Dougb in forum Engine & Drivetrain
    Last Post: 5th May 2010, 09:27
  5. de-restricting airbox
    By chris_20 in forum Petrol Engine related
    Last Post: 25th October 2006, 19:18
1.9 cdti egr flow
