Thread: Gear Change Problem
    salford
    Default Gear Change Problem
    Hi im new to the forum but i have a problem on my vectra which is doing my head in!!! its really hard to find 2nd gear from 1st to 2nd and from 3rd to 2nd. it will find it but you have to be really gentle with the gears to get it in and then your still not guarenteed to get it in. Is it he box or something else? has anyone else had this problem? and if it is the box how much am i looking at for a replacement? thanks in advance.
    Regular Member Jezzy's Avatar
    S.E
    I don't know which gearbox you have, but there's a known issue with the F40, which causes notchiness when going from 1st to 2nd when cold, and when the gearbox has warmed up the notchiness is apparent when going from 2nd to 3rd. Does this sound like your problem? Vauxhall's official fix is to drain the oil out of the gearbox (3.2 litres) and put in 2.4 litres. Later F40's already have 2.4 litres in them, and Vauxhall do state that if the lower level of oil doesn't fix it then there's nothing else they can do to fix it.
    salford
    It's a 1.8 16v ls what box would it be?
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    The 1.8 have the F17 box with either Wr or CR gearing, the F40 box is on the 1.9 oilers. First, have you checked you oil level via the filler level plug? Second when the box is cold I also have to be carefull when changing gear and I have found that by pauseing between coming out of first before going into second the problem almost goes. Hope this helps.
    Telford, Shropshire
    Trim : Elegance
    Engine : 2.2 Direct
    Quote Originally Posted by Goby_Won View Post
    I have the same issue with the same gearbox. Carpets explanation of what to do when changing gears is how i get round it.
    Unfortunatly the gearbox on ours is a sealed unit and has no filler level plug. Also, if you want to change the gearbox oil anyway which is what i intend to do, you have to remove the entire bottom plate from the gearbox and buy a new seal from VX
    Regular Member Rebellion8878's Avatar
    Jul 2009
    Bucks
    Mine is like that, on a 06 1.8 16v vvt but its alright if i'm gentle and when its warmed its fine. Had the oil drained but didn't solve anything, depends where you live as well as I could see this being extremely annoying around town and that if its first thing and cold.
    salford
    thanks for all the replies think im just gonna get a new gearbox i don't do gentle!! is it a common problem or just a few boxes go wrong this way?
    Telford, Shropshire
    Trim : Elegance
    Engine : 2.2 Direct
    Very common, especially with the 1.8. quite a few threads on here about them
    cheshire
    i have the same problem its relly getting on my nerves as it is the second box ive had on the car, the last box got a big crack in it, the f17 box is not a very good box at all. does anyone no will this box last with this problem as i aint got the money yet to get a new one
    cheshire
    Quote Originally Posted by Waterboy View Post
    i was told if u remove the reverse light switch with 13mm ring spanner you can fill oil up that way and undo the oil level plug and when oil start to drip out of the oil level plug the box is full of oil. Dont no how true this is
    check it out c what u lot think
    http://sd-1.archive-host.com/membres...223/boxoil.pdf
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2017, 03:14
  2. gear change problem
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2011, 19:43
  3. when do you change gear?
    Last Post: 21st April 2010, 20:15
  4. Gear change massive problem
    By stitchi1973 in forum Engine & Drivetrain
    Last Post: 19th December 2009, 12:43
  5. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
vectra c notchie gear change
trouble gear changing on vauxhall vectra
how drain to gear box oil on vauxhall vectra 1.8 2003 www.vectra-c.com
vectra c stiff gears
gear oil vectra c f17 change
Vauxhall Vectra Elegance trouble getting into gear
