Results 1 to 10 of 14
Thread: ABS and Traction control light on dashboard
    Sheffield
    Default ABS and Traction control light on dashboard
    Mornin, all.
    I had the dreaded front suspension spring break the other day on my 2004 Vectra c LS 2.0 DTI. Going to work this morning the ABS and Traction control dash lights stayed on. Would the breaking of the front sprint make these lights come on?????
    Carlos
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Check the wiring that goes from the hub. There is a connector that can get water / dirt in it and cause a signal malfunction. Both front sides seem to be affected, most times the connection pins need a clean and all is good again. This is the first place i would look.
    Sheffield
    Good man Ste, I will ave a look soon. Just checking for prices on the front springs now and the guy at the garage said maybe the sensor has been knocked when the bit of spring flew out, and that they are v sensitive.
    Carlos
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The sensor is built into the hub, so that failure mode seems unlikely to me. More like wiring issues.
    Sheffield
    Nice one Ste.
    Cheers Carlos
    Sheffield
    Springs replaced and also (link pins), it turns out both springs where cracked, the only reason I knew one was cracked is that the broken bit flew out. Still got light on dash for ABS and traction. Garage told me that it is the rear passenger side sensor that is faulty, Ive had a look and can see that the corrugated plastic shroud that covers the wires has separated from the housing, I am suspecting water may enter here. Just one thing I cannot for the hell of me work out how to disconnect the sensor plug/connection. Anyone got any ideas or pics.
    Carlos
    Sheffield
    Bump
    Regular Member scottyd's Avatar
    paisley
    must have a plug somewhere near the sensor
    Sheffield
    Ye there is a plug near the sensor, the problem is I cannot work out how to disconnect it
    Nottinghamshire
    Quote Originally Posted by C@rlos View Post
    I had a look in Haynes and they just say 'disconnect it'.
    The picture shows the connector on the back of the hub once the cable has been disconnected and appears to show a tab on the underside of the connector - nearest the back of the hub.
    I would guess that you have to either squeeze the wiring connector in the right place as you pull it off or release a tab with a screwdriver first. Either way, perhaps look underneath the connector first (torch and small mirror may be called for) and see if you can see the retaining tab and how to release it.
  1. ABS and Traction Control Light..
    By integrale in forum Suspension, Wheels & Brakes
    Last Post: 28th February 2012, 15:17
  2. Cruise Control dashboard light not working
    By Weaselbert in forum Electrical & ICE (including SatNav)
    Last Post: 7th March 2011, 15:30
  3. PLEEEEASE HELP - traction control light/power steering light on!!!
    By holdenvectra in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2010, 23:39
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Cruise control dashboard light
    By superstuper in forum Electrical & ICE (including SatNav)
    Last Post: 8th September 2008, 11:17
