Thread: Alternator replaced but now engine management light on?
    Regular Member Dai69's Avatar
    Nr Welshpool
    Vehicle : Vec C Estate X 2
    Engine : CDTi 150
    Year : 55&56
    Mileage : MANY
    confused Alternator replaced but now engine management light on?
    Hi all, I had to replace the alternator, so had a couple of hours chilling on the drive in the snow yesterday afternoon. That's all fine now and the battery is charging nicely.
    Unfortunately now that the car is running again I have the engine management light on and it won't rev past 3000. I've been all over the engine bay checking all of the connections (thought maybe I'd forgotten to reconnect something or had knocked a connection) but haven't found anything obvious.
    Whilst doing the alternator I noticed that the swirl valve linkage has fallen off, so I guess that the inlet manifold needs doing. But, this wasn't causing an issue before doing the alternator, so why should it be start now?
    Please help....Any info/ ideas?
    durham
    he dai69 i need to change my alternator ive got 1998 1.8 vectra any tips and heard ppl takeing from top off car and bottom which is the best way to do it ,also wot tools are needed thanks..
    Nr Welshpool
    Engine : CDTi 150
    Year : 55&56
    Mileage : MANY
    Hi Scouse,
    I'm not sure that any info from me will help you as mine's a 55 Veccy SRi 1.9 cdti 150, but....
    I changed mine from the top, although I did jack it up and remove the offside wheel , just to get at the tensioner and it was easier to refit the belt from there.
    The only tools needed were a couple of torx bits for the tensioner bolt and some bracketry and the airbox, a 10mm spanner for the fuel filter crash box - but you need long thin hands/arms to get at the nuts!! - and an E socket to fit the alternator mounting bolts, although I used a 14mm hexagonal socket!! (you can get away with this only if you have hexagonal sockets - bi-hexagonal will just round off the ends on the bolt giving real problems!
    Oh, I almost forgot, you'll probably need some plasters for your knuckles.
    Hope this info helps and best of luck.
    durham
    cheers dai69 all help is apreciated and i might get a apointed first aid person on hand lol
    Nr Welshpool
    Engine : CDTi 150
    Year : 55&56
    Mileage : MANY
    Good news. The engine management etc has cured itself and is now running as well as ever - even though the manifold obviously needs doing.
    It mist have been sulking because nothing I did was curing the problem but then all faults disappear when I go for lunch?
    Jul 2010
    Wellingborough
    confused Alternator Change
    Hi all new to here..... I had to change the Alternator this weekend,battery charging and Alternator Appears fine, however I now have the engine management light on any ideas anyone.
    Car runs fine everything appears to be working well....what did you mean about manifold needs doing?
    Jun 2007
    Scotland
    I replaced my alternator recently. The engine management light will stay on for about 10 days. After this time the fault code will clear itself and the light will go out. No need to do anything else.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
changed alternator now have eml light on
vectra sri engine management light after change alternator
https:www.vectra-c.comforumshowthread.php103466-Alternator-replaced-but-now-engine-management-light-on
engine management light on after changing alternator
does engine management come on for alternator
vectra 1.9 cdti alternator change www.vectra-c.com
engine management light vauxhall vectra 1.9 cdti
engine management light goes on and off since new alternator fitted
zafira changed alternater now engine light on
