Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Front OS Hub
    Yorkshire
    Default Front OS Hub
    I have taken the three bolts which seem to be holding the Hub on (its abs btw) but I cant seem to get it out! (dejavu lol). What's the best way to get it out?
    Thanks.
    P.S - Its the thing where the wheel lugs fit into.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Have you taken the huge hub nut off?
    Yorkshire
    Yes, It's like it's just bloomin stuck!
    Edinburgh
    Yorkshire
    I'm so confused. I just had a chat to my local garage who said I cant take that piece out or I will break the wheel bearing. He said I need to take the entire leg to him or get the car to him, in which he will take the entire leg off and knock the 'Flange'? out and replace the wheel bearing and put a second hand/new hub on.
    I'd love to be able to do this myself as I have no funds at the moment! How on earth can I do this? The blooming thing wont budge!
    Worst case scenario and I replace the entire leg.. how can I take the ball sockets apart? do I need new ones if I do, or can I reuse them? Any help is greatly appreciated as I am so stuck at the moment.
    Thanks.
    P.S - If I manage to take a Ball joint apart, how do I re-assembly it?
    Admin plasma's Avatar
    On the Forum
    247 Post(s)
    Engine : 150
    Mileage : 74000
    The hub assembly comes off complete... No need to take the leg off.... Once the brakes/disc is off remove the 3 bolts which hold it on and also the hub nut then whack **** out of it to remove it lol... Think mine came off fairly easy, will check the guide to make sure theres not a 4th bolt somewhere...
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    On the Forum
    247 Post(s)
    Engine : 150
    Mileage : 74000
    Just read up on it, you've done all the right bolts I take it? if so then its just old age holding it on..
    Yorkshire
    Quote Originally Posted by plasma View Post
    Thanks for checking up, I cant believe how difficult it is. I have given up for today! I am only using a jack and cant really get a good angle to whack it from behind
    On the Forum
    247 Post(s)
    Engine : 150
    Mileage : 74000
    do bear in mind though that your not hitting the circular ring that it sits in! think best bet is dead centre or such.
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    take the whole knuckle off and use a vice to grip it. i used a 32 mm socket iirc and a hammer to hit the centre of the bearing. Mine was very stuborn but came of after a few hard hits.
  1. SRI Front bumper & Irmscher (copy) Front Spoiler
    By AJA in forum Parts for sale
    Last Post: 10th August 2005, 21:10
