Results 1 to 10 of 15
Thread: Rear brake rewind tool thread pitch
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Default Rear brake rewind tool thread pitch
    Can anyone help me out with the answer to the question that has been preventing me making a new rewind tool
    All I need to know is the threads per inch on the main 'bolt' of the tool. I want to get the correct ratio of rotation to distance pushed in.
    May 2008
    Tyneside
    I have a sealey rewind set and the thread is M16x2, works out at 12.7 tpi. Don't think the pitch is that critical though. HTH
    Regular Member myelite150's Avatar
    Nov 2009
    south wales,Cwmbran
    Quote Originally Posted by tridley View Post
    i agree fully as if the piston does get away from the rewind tool all you have to do is re tighten the sleeve that helps rest againt the caliper
    Regular Member eaglepva's Avatar
    Up North
    Have you made one of these tools yet mate? any pics
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I would have thought that the pitch is critical, as the amount of piston inward movement per rotation is important as to not damage the internal thread, or to not have to constantly reset the tool.
    I will be making a tool pretty soon to replace my original 'low tech' jobbie.
    Once I do I will take pics / draw it if anyone wants to know how to make one themselves. I can't bring myself to buy a tool which will only get used a couple of times, but 10 mins with the welder seems ok to me. £20 is 40 bricks....
    May 2008
    Tyneside
    I thought like you that the disc would always stay in contact with the caliper piston when rewinding. However, there are times when rewinding that a gap appears and the slack has to be taken up by winding out the tool. HTH
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    To me that sounds like the pitch of the tool doesn't match exactly with the pitch of the caliper piston adjuster. But if it works, then maybe it doesn't need to.
    May 2008
    Tyneside
    Not sure how the internal mechanism works but the set I have has sixteen adaptors and I would be surprised if all those makes of car have exactly the same pitch inside the caliper.
    Oct 2009
    Swindon
    Thats why none of the tools have the correct pitched thread, otherwise a new tool would be required for each caliper type.
    I don't think it really makes any difference, it just means retightening the sleeve of the tool maybe once during the process.
    Nov 2009
    south wales,Cwmbran
    Quote Originally Posted by eaglepva View Post
    i made one and got pics too
  1. Brake rewind tool (which one)
    By Middo in forum Suspension, Wheels & Brakes
    Last Post: 22nd May 2011, 17:27
  2. Brake rewind tool
    By scotty84 in forum West Midlands
    Last Post: 26th March 2011, 22:01
  3. rear brake rewind tool
    By wirrallad in forum Suspension, Wheels & Brakes
    Last Post: 16th June 2009, 22:37
  4. Rear brake rewind tool
    By Nickzx6r in forum Parts for sale
    Last Post: 24th November 2007, 17:37
