Results 1 to 2 of 2
Thread: loose connection to headlight
    Nov 2009
    Luton
    Default loose connection to headlight
    hi all, noticed today ive got some dodgy wiring, the main lead that goes to my headlight (xenon) wiggle it one way and the headlamp goes out, another and the sidelight goes out, then the indicator wont work, im assuming its just a case of replacing a section of wiring, im gonna get someone i know to take a look as he is hot on electrics so i hope i get it sorted soon, the main shrouding looks butcherd so i think someone before me has made a hash of something. i dearnt take it to vauxhall cause you know they will want to replace the loom and countless modules! anyone else had a prob like this?
    May 2008
    Tyneside
    I had a problem with my dipped headlight connector. Turned out the headlight terminal was not entered into the spade connector in the plug but behind it causing a heat build up and melting some of the plastic connector.
  1. Oil Seperator Connection Loose
    By john506 in forum Engine & Drivetrain
    Last Post: 17th January 2012, 13:56
  2. Anyone know which connection??????????
    By VECTRA1974* in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2011, 01:38
  3. What do I loose?
    By DaveD in forum Electrical & ICE (including SatNav)
    Last Post: 2nd June 2009, 18:01
  4. Loose connection on front cluster
    By Merick in forum Electrical & ICE (including SatNav)
    Last Post: 1st May 2007, 17:01
  5. At a loose end???
    By marichrd in forum General Chat
    Last Post: 27th June 2006, 21:51
