Results 1 to 10 of 15
Thread: Problems already
    Nov 2009
    SCOTLAND
    Default Problems already
    Had the insignia for a few months now ,couple of problems developed. Front driver side indicator and side repeater not working ,all bulbs are ok . And a wee problem with the idle,sits at 1000 revs most of the time then sometimes settles back down to 800. Scary thing about it is sometimes you can feel it trying to shoot away from you on approach to junctions and roundabouts Its a diesel se with all the toys and am still loving it even with the faults..Booked in friday so hopefully it will be good as new
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    The later issue of changing revs, when ticking over could be caused by the MAF, VX have had a few go faulty on the Insignia, causing the mixture to vary wildly.
    Hopefully the dealer will sort it for you matey when you take it in.
    Mar 2007
    North East
    The idle speed is a response to the charge state of the battery.
    Vx Info:
    Insignia 2009-Onwards – Engines A20DT/C/H/J/L/R
    Increased idle speed
    Customer complains of an increased idle speed up to 1150 rpm.
    Increased idle speed signal is managed by the engine ECU but based on a signal coming from the BCM
    (Body Control Module).
    If the state of charge (SOC) for the battery is too low the BCM urges the engine ECU to increase idle
    speed in order reload the battery in a proper way. There are three possible idle speed steps going from:
    -- step 1 (= 925 rpm) to
    -- step 2 (= 1000 rpm-1050 rpm) and
    -- step 3 (= 1100 rpm-1150 rpm)
    The step is dependent on the SOC as well as the outside temperature, which also affects the SOC.
    Other possible reasons for increased idle speed also managed by the engine ECU based on a BCM
    request:
    a.) During auxiliary heater on the idle speed will be set to step 2.
    b.) During HVAC operation the idle speed will be set to step1-3 based on the thermal load.
    c.) During DPF regeneration mode the idle speed will be set to step1-3 based on the engine
    requirements.
    In case of customer complaint please explain this technical content to the customer.
    Nov 2009
    SCOTLAND
    Quote Originally Posted by rockh View Post
    Vx Info:
    request:
    requirements.
    So are they saying its supposed to over idle ????
    Mar 2007
    North East
    Yes, to ensure the battery is properly charged.
    Nov 2009
    SCOTLAND
    Cheers , i'll see what they say tomorrow.One things for sure,i shouldnt be able to drive with my foot off the gas pedal which it does. lol
    Mar 2007
    North East
    Know what you mean.
    Regular Member kdadidog's Avatar
    county durham (peterlee)
    Quote Originally Posted by bigal66 View Post
    I can do that in my vectra 1.8 LS. its like my party peice. think it just revs a bit to stop it from stalling. I actually once got out going up hill with my mate in the passenger seat. his face looked like this . he had to jump over and stop it.
    Hanging Heaton / Batley
    14 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Quote Originally Posted by kdadidog View Post
    Can your mate take a video of you jumpin out the drives side, running round the front and getting into the passenger seat
    Regular Member shaun260589's Avatar
    Jun 2009
    Newcastle
    This post useless with out youtube link
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. GSi problems
    By Piemyster in forum Engine & Drivetrain
    Last Post: 27th July 2011, 20:11
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
