Thread: Any one any ideas??
    bournemouth
    Default Any one any ideas??
    okay im hoping someone could answer my question
    basicaly yestoday i was driving along in my signum and the light on the dash with a pic of a car with a spanner suddenly came on and it went into safe mode so i pulled over and and turned the car off and looked under the bonnet but couldnt find anything wronge, so i started the car back up and the light was off so i carried on my way and it happend again after a little while
    does anyone know what could be wronge or is there a way of finding out whats up by doing a paperclip test or something
    Nottinghamshire
    The spanner light covers most systems on the car except the few that have their own fault light (e.g. ABS) so it could indicate any one of literally hundreds of fault codes. What symptoms did you get? Power loss, perhaps?
    The paperclip test doesn't work on the Vectra C. What engine have you got? It might be one that works with a method which is covered on this site that involves holding down the pedals while turning on the ignition and then watching a flashing light.
    Failing that, it's got to be a fault code reader. The specification of the fault code reader will determine what codes can be read - some can only read engine codes while others can read all codes, while the DTi engines don't like to talk to anything except a professional dealer/garage reader .
    bournemouth
    ive got a 2004 signum 1.9cdti 120 and i get a loss of power as if it has no turbo so to speak
    Regular Member woody in shetland's Avatar
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    In the Manuel "i think" it says that if the spanner light comes on and goes out again after restarting then basically carry on and dont worry about it, i'm sure if there was something seriously wrong the spanner light would stay on, mine does it now and again, if it persists then by all means have it checked out via tech2 or if you can do the pedal test all the better. Most likely a small glitch in a sensor or something, there's so many. If my advise is wrong then hopefully someone will correct me
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    I would suggest you look at the small vacumm hoses to check for splits and also the big boost hoses for the same, maybe worth taking out boost sensor for a clean as well. I cant tell you where it is on a 1.9 as i have a 2.2 DTi but it sounds the same symptoms im sure some-one will be along to tell you exactly where the sensor is. HTH
    Nottinghamshire
    Quote Originally Posted by Daywalker View Post
    The CDTi has a vacuum-operated turbo wastegate solenoid. I don't know if there are any other vacuum-operated things on it.
    It will have air hoses but the engine layout is very different to the DTi so I can't advise how many there are or where.
    bournemouth
    well had it tech 2 today and it seems its the partical filter sits going back into the garage on thurday to see if they can clean it throw
    hopefully it will solve the problem
  1. Anyone got any ideas
    By paulvectrac in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2011, 16:42
  2. Ideas Please
    By Tomb in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2010, 16:21
  3. Any Ideas ???????
    By johnnyd2003 in forum Engine & Drivetrain
    Last Post: 16th April 2009, 21:13
  4. Any ideas as to what this is
    By Baz07 in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2008, 21:21
  5. Any Ideas?
    By steve in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2008, 16:49
