Thread: Clutch bleed problem
    Regular Member Gazza36's Avatar
    Jan 2010
    Cornwall
    Default Clutch bleed problem
    Hi, tried to bleed the clutch today using a one-way valve kit, however although I managed to get some fluid out after a while it wouldn't push anything out. The pedal goes to the floor so there is obviously air in there, but I can't understand why it won't push any fluid out, the level in the resouvoir stays the same. Any help greatly appreciated, Gaz.
    Bristol
    Vehicle : CDTI 150
    Vec C has a concentric slave cylinder, you need to use the old fashion two person method.
    One in car other at bleed nipple.
    Open bleed nipple depress clutch, close bleed nipple release clutch slowly etc.
    Keep an eye on the fluid level.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    What about an Eezibleed? VX bleed the clutch backwards, as in they push the fluid in from the nipple and out the reservoir.
    Bristol
    Vehicle : CDTI 150
    Easibleed attaches to the brake/clutch fluid reservoir and pushes the fluid through.
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by lesj View Post
    Yes, I have one, used it on the punto clutch, surely its going to work the same on the Vec.
    Jan 2010
    Cornwall
    Hi, bought an eezibleed and had no problems, great bit of kit, thanks for the replies Gaz.
  1. How to vacuum bleed clutch?
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 28th November 2012, 22:31
  2. Clutch bleed nipple
    By Imraldis in forum Vectra C / Signum Car Chat
    Last Post: 9th October 2012, 21:19
  3. Clutch Bleed
    By mat_splat in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2012, 19:36
  4. how to bleed the clutch
    By vectra3.2dave in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2010, 14:26
  5. Brake and Clutch bleed
    By GoldenWonder in forum Suspension, Wheels & Brakes
    Last Post: 11th September 2008, 20:21
vectra z22se clutch bleed
bleeding the clutch on a 2004 Vauxhall Signum
clutch bleed vectra c z22se
